Home depot R-30 shows 58.67 total square foot coverage divided by the width of batt = 1.33 = 44.11 divided by each one is 4' long =
11 pieces.
http://www.homedepot.com/Building-Ma...1#.UTfdI1KsnAU
Keep in mind, R-30 is one of the lowest density batts out there at 0.57# per cubic foot- compress it to R-26 (medium density) or further still to R-15 (high density, pp.41;
http://www.huduser.org/Publications/pdf/walls.pdf), compare Roxul at >2lbs/ft3;
http://www.roxul.com/files/RX-NA-EN/...th%20steel.pdf
Air seal the attic first, and use a housewrap over the low density batts to prevent wind-washing degrading you thermal barrier.
Gary
Clothes taking longer to dry?
