Caulking Between Drywall - Insulation - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 01:32 PM   #1
Rewards Points: 169
Caulking between drywall
I have a few small .5" gaps between my ceiling and wall. I plan on putting up crowns anyway, but I wanted to insulate it.
What should I be using? I'm completely clueless when it comes to this. A low expansion foam?
RCGA is offline   Reply With Quote
Old 04-08-2013, 01:36 PM   #2
Rewards Points: 744
Normally, you would tape and mud those corners. Unless the walls were decoupled for a soundproofing installation, then you would use an acoustical sealant. That's not to say that caulk wouldn't seal that gap..
Seattle2k is offline   Reply With Quote
Old 04-08-2013, 01:46 PM   #3
Rewards Points: 169
Mud was applied to all the bedrooms but not to this main living room because we're were putting up crown mouldings and wanted to save some money.
Old 04-08-2013, 03:15 PM   #4
Rewards Points: 626
half inch gaps hot mud and paper tape. will seal it up just fine and won't crack.
Nailbags is offline   Reply With Quote
Old 04-08-2013, 05:34 PM   #5
Rewards Points: 744
How much did you save by going that route?
Old 04-08-2013, 05:47 PM   #6
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 722
Sorry, hot mud? ........... for us clueless guys.
Thanks,
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 04-11-2013, 02:28 AM   #7
Rewards Points: 626
Thanks,
No problem every one is learning it is mud you mix that has a chemical reaction with the water less srinkage and stuff here is the link to USG http://www.usg.com/sheetrock-durabon...-compound.html
The Following User Says Thank You to Nailbags For This Useful Post:
123pugsy (04-11-2013)
Old 04-11-2013, 08:17 AM   #8
123pugsy's Avatar
Rewards Points: 722
Thanks.
I guess the reaction warms it up thus the "hot mud" term.
Old 04-11-2013, 09:46 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
If you are putting up crown, a good acrylic latex will work fine to seal the gap as well prior to the crown installation.
Hot mud...
Maybe I am just a guy with a simple sense of humor but that make me chuckle.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Nailbags (04-11-2013)
Old 04-11-2013, 03:12 PM   #10
Registered User
Rewards Points: 5,212
Just be sure it is fire-rated caulk, especially if leaving a gap between crown/ceiling; http://www.google.com/#hl=en&sclient...iw=853&bih=489
"4.6.7 When gaps occur at gypsum panel product joints, they
shall be not greater than 1/4 in. (6 mm) and shall be prefilled
with joint compound as specified in Sections 4.6.7.1 and
4.6.7.2.
4.6.7.1 Gaps not greater than 1/8 in. (3 mm) shall be prefilled
with either ready-mix or setting-type joint compound.
4.6.7.2 Gaps greater than 1/8 in. (3 mm) shall be prefilled
with setting-type joint compound." From; http://www.lafargenorthamerica.com/G...%20English.pdf
That way you keep the fire rating of the wall/ceiling drywall used in houses just for that purpose; to keep the wood framing from burning.
Gary
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
