Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 06-27-2011, 08:09 PM   #1
cathedral ceiling soffit venting
we have standard ridge vent, cathedral ceilings and want to install soffit venting. Our eves are a four foot overhang. the question is how much soffit venting do we need. Can we install vented soffit to cover the entire four foot overhang or will this be too much and effect the venting.
david palumbo is offline   Reply With Quote
Old 06-27-2011, 08:54 PM   #2
Moderator
Welcome to the forum!
Ridge vents come in different NFVA per manufacturer: http://www.inspectapedia.com/interiors/atticcond10.htm
You need to find the NFVA of the ridge to figure the NFVA of the soffit vents (one in every bay) and closest to the fascia board away from the house for best air flow, pp 616: http://books.google.com/books?id=Z8a...0vents&f=false
You don’t want the vents to and from the house, rather, perpendicular to the house.
I hope you used baffles to create an air channel all the way to the ridge leaving only 1” gaps abutting them: http://www.bergerbuildingproducts.co...sAccuvent.html
Will you be using ADA on the drywall? http://www.buildingscience.com/docum...wall-approach/
Where are you located?
Gary
Clothes taking longer to dry?
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 08:54 PM
Venting Cathedral ceiling dodge1930 Building & Construction 2 10-15-2010 11:07 AM
Cathedral ceiling, opening ceiling Blackwater Remodeling 8 03-12-2010 03:08 AM
Cathedral ceiling sharp Building & Construction 5 02-26-2010 11:18 PM
Could lack of soffit venting increase indoor negative air pressure? creamaster Roofing/Siding 1 03-07-2009 02:27 PM
