Cathedral Ceiling Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 02:09 PM   #1
I am building a cabin with a roof design for Valdez Alaska. 12/12 pitch with BCI 60 I joists. (2 5/16" x 14") on 16" centers. Vented at the top and bottom of all spaces. From looking on the net I've found R38 to be 10 1/2" or 12" thick. I'd like to use a kraft face to avoid any sliding issues. Will 3 1/2" vented space be to much if I use a 10 1/2" thick insulation. Not a carpenter, this place built by a safety man, truck driver and a dirt worker.
AKHermit is offline   Reply With Quote
Old 10-16-2011, 04:16 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
3.5" is fine. Make sure you use a HD batt in this application.
I would also like to see some insulation webbing or housewrap between to the joist bay and the venting space to prevent the wind washing of the insulation.
The Following User Says Thank You to Windows on Wash For This Useful Post:
AKHermit (10-16-2011)
Old 10-16-2011, 05:53 PM   #3
Are you suggesting something like this.
http://www.brentwoodindustries.com/s...l-Ceiling.aspx
Old 10-16-2011, 08:37 PM   #4
Yes, but you can do it with Tyvek just he same.
Old 10-16-2011, 08:54 PM   #5
Registered User
Rewards Points: 526
Here in WA State, our energy code requires R-38 in cathedrals, minimum, with only -5k Heating Degree Days. You have -10k HDD for your location. I’d use 1-1/2 inch air space and foamboard, then cellulose, drywall, latex paint as on page 31, here; http://www.buildingscience.com/docum...-climate-zones
Or the fiberglass with foamboard under the drywall as in the next picture, for a thermal break from the cold rafters (though they won’t transmit much as engineered-not solid wood). If the slope was shallow, then bigger airspace is recommended.
PS- check out their recommendations for your zone 7 on page 11.
I would not use any baffles that don't advertise the net free air venting rate on the spec. sheet. Example- At H.D.- http://www.bergerbuildingproducts.co...sAccuvent.html
And O.C.- http://www.owenscorning.com/around/v...s/VentSure.pdf
Notice the gap between baffle ends for condensation relief....
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AKHermit (10-19-2011)
Old 10-16-2011, 09:23 PM   #6
I like Gary's roof approach better.
Rigid foam against the inside edge of the outer flange, insul web the joist bays, blow cellulose, and then a layer of rigid foam against the inside surface.
You would have a vented near R-50 insulation layer at that point.
Old 10-16-2011, 10:40 PM   #7
I think I should add that this is a recreational cabin off the road system. Access by snow machine, atv or walking.
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Garage Cathedral Ceiling Insulation onecanoe Building & Construction 1 05-01-2008 03:28 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 09:55 AM
Cathedral ceiling insulation Unregistered Building & Construction 2 09-17-2005 12:21 AM
