Cape Cod Side Attics - Insulation - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 11:43 PM   #1
cape cod side attics
Can you insulate both the roof in the side attic if you baffle it and the kneewall going the entire length or no? I have been told multiple answers. There is a soffit that is vented the whole length and a ridge vent at the top of the roof. In NY.
capecodfun is offline   Reply With Quote
Old 10-23-2011, 01:35 AM   #2
Rewards Points: 1,092
I don't quite follow exactly what your situation is, but you are welcome to insulate wherever you want to, as long as it is ventilated on the outside (spray foam against a roof is an exception). More importantly, air seal on the conditioned side (heated side) before you insulate. Stopping air is A#1, then insulate.
Old 10-23-2011, 09:04 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
Insulation layer and air barrier need to line up and occupy the same plane.
In this case, if you have eave venting (soffits) your air barrier should be on the kneewalls as well as your insulation layer.
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 02:51 PM
"smooth" side on hardie backer amakarevic Building & Construction 2 04-12-2011 10:43 AM
Maytag Side by side dannykapp Appliances 25 02-27-2011 09:25 PM
Installing a water line for a side by side fridge mhp8982 Plumbing 43 09-20-2010 02:21 PM
GE Side by side water dispenser not working cfinchapex Appliances 3 09-19-2009 10:39 AM
