Cantilever Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 12:54 PM   #1
Cantilever insulation
I have a 1950's era rancher with two bedrooms that extend approximately 2.5 feet beyond the concrete foundation wall. Using the information from this site I plan properly insulate the basement prior to finishing the space (2-inch XPS, 2x4 framing, batting, drywall).
To that end, I ordered a DIY spray foam kit and plan to spray the cantilevered bays under the bedrooms, as well as the rim band around the entire foundation. I have already cut, glued 2-inch XPS into all the other bays & spray foamed the spaces around them. I have attached a picture of the bay that extends out from the corner of the foundation. For the cantilever bays I planned to spray all joints (red lines in picture), then cover the exterior joist surfaces (A & C) and overhead floor surface (B) with foam 2-inches thick (two 1-inch applications).
My question is should I spray the plywood surface that is nailed to the bottom of the joists (E)? Or, if I have enough material, hit all surfaces within the bays?
It is my understanding from reading other threads in this sub-forum that I should block off this open space above the rim joist with FB insulation. Can I cut 2-inch XPS and spray foam that block into place? Do I gain anything by doing the latter or am I just isolating any air from the basement from warming this bay in the winter?
Rowden is offline   Reply With Quote
Old 09-02-2013, 09:16 PM   #2
Rewards Points: 152
Bookmarked this thread from a while ago, lots of pics and seemed like the right way to do it?
Insulating an Overhang
burnt03 is offline   Reply With Quote
Old 09-03-2013, 05:01 PM   #3
Thanks Burnt03, I did take a look at that thread on several occasions. While those projects were undertaken from the exterior and involved combinations of XPS & batting, I'm planning to hit the interior with a large volume of spray foam.
Maybe I'm being overly cautious but I'd like to get a few opinions on how best to distribute the foam before doing so because once it's on it's too late. I'm assuming spraying all the surfaces is the best option (twice on overlying floor and exterior joists) but I wouldn't be surprised if it was recommended to skip spraying the bottom and use that foam for a third layer on the top (R value of 12-14 on top and 6-7 on bottom vs R value of 18-21 on top only). Should I install some Roxul in the remaining void before sealing the box above the rim joist?
Thanks for bearing with me.
Old 09-05-2013, 05:59 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Good read in the other thread.
Can you post up a picture from outside of the construction and access?
Old 09-05-2013, 04:01 PM   #5
Registered User
Rewards Points: 526
Airspace on top with f.b., Fig.7, airspace on bottom with SPF, Photo 6; http://www.buildingscience.com/docum...n-crawlspaces/ Decouple it from exterior ground temps. Cover with soffit of choice.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Rowden (09-05-2013)
Old 09-05-2013, 04:23 PM   #6
It is standard construction with plywood sheathing covered by vented vinyl soffit. Approximately 3 feet of clearance from ground to soffit.
Old 09-05-2013, 04:48 PM   #7
Gary
Thanks, Gary. If I understand this correctly since the floor joists are encased (as is the case in Photo 6), it would be best to place as much foam insulation on the bottom/sides and leave an airspace on the top (Figure 7). Which is counter to what I had proposed...not surprising though.
Since the bays are 7-inches in height and I'm shooting for at least 3-inches of foam on the bottom sheathing, that would leave enough space for me to insert 3.5-inch un-faced fiberglass batting. That's assuming it doesn't get torn up by all the nails penetrating the sheathing.
Unless I'm missing something that's the approach I'll plan to take.
Old 09-24-2013, 08:29 PM   #8
Registered User
Rewards Points: 526
Little late, sorry... http://www.buildingscience.com/docum...al-performance
Gary
Old 10-14-2013, 08:01 AM   #9
Just wanted to follow up with a few pictures of the completed project. I used Foam It Green 202 spray insulation in all the bays and managed between 2 & 3-inches of coverage on exterior facing surfaces. The spray foam was very easy to use and I'd recommend it to anyone looking to do their own closed cell insulation job. Covered that with batting then sealed the space with 2-inch XPS. Finished with batting over the XPS.
Thanks for everyone's assistance.
Now onto the covering the walls with 2-inch XPS and framing.
Cantilever insulation-img_0866a.jpg   Cantilever insulation-img_0868a.jpg   Cantilever insulation-img_0875a.jpg   Cantilever insulation-img_0877a.jpg   Cantilever insulation-img_0878a.jpg
Old 10-15-2013, 07:31 PM   #10
Registered User
Rewards Points: 526
You will still get thermal bridging of the floor joists and bottoms are still radiation coupled per link. Will you remove faced insulation when finishing?
Gary
Old 10-16-2013, 07:15 PM   #11
I'm primarily focusing my attention & money on the interior of the space at the moment (insulating & framing walls, leveling floor, replacing windows, etc). To do the cantilevers correct, per the link, I'll have to revisit the exterior which will require some aluminum flashing, etc to accommodate the new layer of rigid insulation.
I was planning on leaving the faced insulation between the joists. I realize that now that the room will be heated the insulation does not serve any purpose beyond possible noise reduction. Is there any recommendation / documentation that says there is a benefit to not having the insulation in place?
Old 06-28-2014, 10:31 PM   #12
Hi Rowden, I don't know if you are still visiting this thread but here's my question.
I'm planning to spray foam the overhang (cantilevered joists) in my basement using Foam It Green 202. I saw in your post that you applied couple of inches of the foam and then put fiberglass insulation on top of that. Do you see anything wrong if I fill whole cavity with foam it green? Also, the instructions say that after applying 1inch of foam I need to wait 10 min to cure but I will have to replace the spray tip after 30 seconds. Did you wait 10 min after spraying the first coat? Thank you
joco101 is offline   Reply With Quote
Old 06-29-2014, 08:49 AM   #13
Joco,
I'm not an insulation expert but I would think that would be overkill. You're sealing off the air leaks with one layer, which is probably the biggest thermal issue. Each additional layer would have a benefit, but at some point I would assume it wouldn't be worth it anymore. Depending on the depth of the cantilever, you might need 2-3 spray tanks ($$$). Plus, as Gary mentioned earlier, you would still have thermal bridging from the joists.
I had 20+ bays to insulate so by the time I finished one pass, the first bay had sufficient time to cool (spray two bays, move ladder, spray bays, untangle hoses, etc). The spray tool is good and the first coat was fairly uniform, but subsequent coats were not as uniform because it became more difficult to get my arm into the bay without getting messy. I did have to change the tips a number of times, even though I kept working the entire time. If you sprayed the back face (labeled "A" in my 1st picture) and worked out you could probably do it without too much mess vs covering three sides at the same time.
I am pleased with the results of my insulation project. This past winter was colder than normal and the floors were noticeably warmed than before. The big issue was moisture and condensation on the inside walls of the cantilever corner, which we did not experience this year.
Again, just my opinion. Hope this helps.
Old 06-29-2014, 09:41 AM   #14
Thank you for your fast response Rowden. I'm going to put one or two layers of spray foam to seal the air leaks and then stuff some fiber glass insulation.
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 08:26 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
