Cantilever Floor - Insulation - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 12:07 AM   #1
Cantilever floor
Anybody have any links to specs and/or diagrams on how to properly insulate an exposed floor with plumbing? We are doing an addition that will sit on columns/footings so the bottom side of the bathroom floor will be 'exposed'. Under the addition is landscaping and egress windows in the basement.
We are in central wi so the winters get pretty cold and I am concerned about the water lines and drains freezing.
I had intended in fiberglass insulating the floor cavities and putting 2-3" of foam board across the bottom... Any suggestions?
Sent from my iPad using DIY Forum
Justgaff is offline   Reply With Quote
Old 04-20-2012, 12:08 AM   #2
Sorry-it's not technically cantilevered-I forgot to change the subject line...
Old 04-20-2012, 12:17 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
More depth for insulation and a thicker foam.
Make sure that you consider perm ratings and air barrier detailing.
Old 04-20-2012, 05:08 PM   #4
Registered User
Rewards Points: 5,212
http://www.buildingscience.com/docum...n-crawlspaces/
No vinyl above. Cover with plywood, trim. Just verifying.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Justgaff (04-22-2012)
Old 04-22-2012, 08:27 PM   #5
Gary
Awesome article! Thank you!!
The Following User Says Thank You to Justgaff For This Useful Post:
Gary in WA (04-22-2012)
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 10:12 AM
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
