Can/should I Add Insulation Underneath Stationary Stairs To My Attic? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-28-2012, 03:12 PM   #1
Can/should I add insulation underneath stationary stairs to my attic?
Pictures: http://imgur.com/a/Mlf9W
We recently bought a house built in 1920 in southern ontario (the climate varies from -30C to +40C) with an attic accessible via a permanent staircase. For the most part, the attic has good insulation (sorry, I don't know the exact R value). The previous owners did spray insulation underneath the attic floor and there is fiberglass insulation stuffed around other places.
The problem is that I think our staircase is a major source of heat loss. The entranceway to our house is underneath these stairs and it's always the coldest part of the house. Furthermore, when you first walk into the attic stairs (see pictures), it is quite warm. It's not cold until you walk up right into the attic. Finally, we recently had snowfall and saw that the snow on the roof directly above the attic stairs melted before any other snow did.
I pried up a floorboard on the attic stair landing and looked inside. It appears completely hollow.
QUESTION: Can I shove fiberglass insulation or spray insulation into this area to help with heat loss or is it supposed to be hollow underneath stairs?
Thanks!
Bitruder is offline   Reply With Quote
Old 12-28-2012, 09:33 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Spaces between conditioned spaces do not need to be insulated but they do need to blocked off from outside airflow. If the attic is vented, they need to be blocked off with rigid foam (with an approved ignition/thermal barrier).
I am having a bit of a difficult time piecing together the pictures. Any chance you can get some wider shots?
Old 12-28-2012, 10:35 PM   #3
Registered User
Rewards Points: 4,936
Without an insulated door/hatch at the top of the stairs, you need to insulate the stair walls, floor, risers/treads, and door since they are coupled to the interior conditioned spaces. You have an effective stairwell heat-sink there... the reason it is warm when you step inside the well. You have no thermal boundary established, air-seal the attic first; http://oee.nrcan.gc.ca/publications/residential/9373
Gary
Old 12-29-2012, 12:04 AM   #4
Rewards Points: 906
Gary
+1
I didn't see one but I didn't even think to recommend that. Thought it would have been a standard.
Attic insulation / venting of 60s era house Chokingdogs Insulation 6 11-11-2012 10:32 PM
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 12:50 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
