Can Foam Board Be Used On Interior? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 03:24 PM   #1
Rewards Points: 264
can foam board be used on interior?
i have an old 2 story farmhouse. the bathroom was gutted. the exterior walls are only 2x4 so r-13 insulation is being used.
On the face of the 2x4's can I use 1" foam board to give another r-5? then drywall over it.
What would the drawbacks of this be?
thanks
What have I done is offline   Reply With Quote
Old 11-10-2012, 08:03 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
Drawback of this is that it will keep the framing even more cold and therefore increase the chance of condensation on them.
Foam to the inside is not a great idea when you are talking about covering the studs.
If you want additional R-Value in that wall, cut foam board to fit inside the wall and do a layer of foam first, then the batts.
Old 11-10-2012, 10:00 AM   #3
Rewards Points: 140
this is what i was told to do, here. seems to be working very well. i am also going to do 1" xps under new siding.
Fix'n it is offline   Reply With Quote
Old 11-10-2012, 10:37 AM   #4
Too Short? Cut it Again!
Check your local building/fire code. Most foam board is not fire rated and code may call for you to cover it with a certain thickness drywall. I am fairly certain you could not meet code unless the foam was inside the framing and then covered. And as mentioned, you do not want to create a moisture barrier.
If you really want the r value, you would better off finding someone to come out and spray foam into the cavities if you can find someone willing to do a small job.
Old 11-10-2012, 04:44 PM   #5
Registered User
Rewards Points: 4,912
If you do "cut-n-cobble" to the cavities, use EPS rather than more expensive XPS, and it's a lot "greener" because of the blowing agent used.
1. Any OSB in the wall make-up?
2. Where are you located?
Gary
Insulating Existing Garage with Polyiso Foam Board saxman2u Insulation 6 09-18-2012 02:45 PM
Foam board over old 4in thick fiber board roofing panels Rebob40 Roofing/Siding 2 03-05-2012 10:24 AM
Ridged foam board in attic, going for R-40 sentz Insulation 6 03-04-2012 01:27 PM
rigid foam board on basement floor is it good or bad cutnail Insulation 6 08-29-2011 08:48 AM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 09:17 PM
