Cabin Floor Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 12:18 PM   #1
Greetings,
I am building a small one room cabin. 14'x16'. Located in Western Wisconsin - wet summers, cold winters. The cabin will only have a wood burning stove and will only be used for occasional occupancy.
I am thinking I would still like to insulate the floor - even though we will only be occasionally using it in the winter. I have proposed a 2x4 subfloor structure on top of a deck joist system (already built).
I'm thinking putting 1/8" galvanized metal screen between the deck joists and the subfloor to keep the critters from chewing on the fiberglass and then laying fiberglass batts in betwen the 2X4 subfloor. Not a ton of insulation but better than nothing? Will this work?
Picture enclosed.
Thank you so very much!
Davef_dci is offline   Reply With Quote
Old 03-09-2013, 01:12 PM   #2
I would use foam!
2" foam panels or the spray in foam!
Hardway is offline   Reply With Quote
Old 03-09-2013, 01:22 PM   #3
http://www.homedepot.com/catalog/pro...d2bf21_300.jpg
Old 03-09-2013, 06:28 PM   #4
Rewards Points: 13,270
Not sure where you got those plans but none of that makes any since to build it that way.
If that part of the plans you posted before, even the way there showing the roof is out of wack.
Old 03-10-2013, 12:00 AM   #5
Rewards Points: 175
If you put mesh under the joists why not fill the 2x8 or 2x10s with fiberglass AND the 2x4s with fiberglass? You have a blank slate might as well do it well, besides fiberglass is dirt cheap.
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Grounding at the cabin scamilleri1228 Electrical 15 09-23-2011 01:57 PM
Log cabin re-wire advice on lighting (nec questions) eek Electrical 6 09-16-2011 11:20 AM
Moving Cabin from crawlspace foundation to slab rgood44 Building & Construction 2 08-23-2011 08:37 PM
BIG PROBLEMS with cabin mud sills and floor scylla2 Building & Construction 1 10-18-2009 09:34 PM
Can I set a cabin on top of mobile home slab? birchbarx Building & Construction 4 03-22-2008 07:06 PM
