#1 |
bsmt wall insulation
Hey,
I live in Saskatchewan, Canada and we have an uninsulated concrete bsmt. I was planning on just putting up 2x4 walls to conserve space. I've heard most heat is lost through bsmt so wondering if 2x4 walls are enough for bsmt and also what type of insulation is recommended batt or foam board? Also should studs be treated? or just bottom plate? do I put plastic under the bottom plate? what is the recommended way of fastening walls to floor? thanks |
#2 |
"You can do anything"-Mom
http://www.buildingscience.com/docum...ding-basements
This should get you started. Treated lumber for sole plates. Use a sill gasket under as well to provide a capillary break. |
| The Following 2 Users Say Thank You to brockmiera For This Useful Post: | durango sweepy (01-23-2013), jklingel (01-28-2013) |
| Display Modes | |
| Insulating your attic | Bob Mariani | How To Guides | 4 | 06-09-2013 11:48 AM |
| Colonial Split level | drew7ster | Insulation | 11 | 01-09-2013 04:44 PM |
| Where to apply vapor barrier(s) for wall insulation | patented | Insulation | 6 | 10-30-2012 12:17 AM |
| Trouble with staggered wall | rightit | Building & Construction | 2 | 03-09-2011 07:23 PM |
| Marrying a sloping stone wall to a cinder block wall. | mrdol | Landscaping & Lawn Care | 1 | 11-09-2007 05:08 PM |
