Brick House, No Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 11-29-2013, 11:33 AM   #1
Brick house, no insulation
We have a brick home built in the 50s. It has plaster walls with about a 2" gap between the plaster and brick with no insulation. I have read all the debates regarding insulating behind the existing walls. So here is where I need help. Could I build 2x4 walls over the existing plaster and insulate them and then cover them with drywall? What would be the steps? Vapor barrier? There is none in the cavity now. The house is on a slab. I live in northern Indiana where it is cold and windy in the winter. The exterior walls are very cold to the touch. I have insulated the attic.
Thanks for any help you can give!
Randy7652 is offline   Reply With Quote
Old 11-29-2013, 04:08 PM   #2
Rewards Points: 13,216
If there's A 2" gap what's the plaster attached to?
Contacted any local company's that do foam insulation yet to have them do any on site quotes?
You could add that wall but you would also have to add jamb extensions to all the window and doors.
Old 11-29-2013, 04:23 PM   #3
Rewards Points: 940
I'm interested as well as to what the plaster is attached to.
Maybe a bunch of goony feathers?
cleveman is offline   Reply With Quote
Old 11-29-2013, 09:43 PM   #4
Registered User
Rewards Points: 5,180
Apparently no sheathing on the studs.... just the cavity/air space (required for brick veneers) that you don't SPF directly on the brick. http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Gary
House wrap meets brick house question joshv Building & Construction 5 09-15-2012 10:26 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How to handle insulation on Cape Style House ksuclipse Insulation 8 09-16-2011 09:56 AM
Ugly brick on front of house jetrep General DIY Discussions 5 06-01-2011 07:58 AM
Addition to a veneer brick house DUNN-IT Building & Construction 4 03-19-2008 09:14 AM
