Brick Chimney Wall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 09:44 AM   #1
Question
I pulled off the paneling in my living room to re-insulate and drywall it, and found a brick wall in the middle of the wall - it's the chimney from my basement fireplace.
There was no insulation over the chimney, and they had some fibreglass insulation beside it... my question is:
What can I use to safely insulate an interior brick chimney wall? Can I cut roxul into 1" batts and put it against the chimney? Should I be using some sort of rigid insulation? Or should it be left alone, with a 1" gap between my chimney wall and the new drywall?
rugbyfan is offline   Reply With Quote
Old 08-25-2013, 09:59 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Roxul is probably your safest bet.
Tags
brick chimney , insulation , roxul
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Insulation behind brick chimney? scoutn General DIY Discussions 13 11-15-2010 05:39 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 07:41 PM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
