Blown In Wall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 01:37 PM   #1
Rewards Points: 53
Blown in Wall Insulation
Does the forum have any feedback on blowing in insulation into walls? I’ve received feedback from “it’s great and really helps” to “it’s useless as your home should have existing insulation in the walls and there’s no way enough insulation can be blown in that will make a difference.”
My house is in Chicagoland, IL, was built in 1975 and has vinyl siding
I am exploring blowing in insulation for the master bedroom and the baby’s room. the walls are exterior facing and they will drill a row(s) of 2" holes that are spaced apart every 16 inches, blow in cellulose insulation under pressure to fill each cavity, plug holes and apply one coat of compound.
Does anyone have any positive or negative feedback on blowing it into the walls?
majch is offline   Reply With Quote
Old 03-23-2012, 01:50 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
I don't know who said it is worthless but they are plumb wrong if they did.
Are you sure that you don't have any insulation in there?
Old 03-23-2012, 01:59 PM   #3
Rewards Points: 53
I don't know how to tell if there's insulation in there? The walls are drywalled and we've only lived there 2 yrs.
Old 03-23-2012, 02:22 PM   #4
You will need to identify that first.
Old 03-23-2012, 03:20 PM   #5
Civil Engineer
Rewards Points: 4,940
Windows is spot on, of course adding insulation to an uninsulated wall will help with heating costs immensely. I had insulation blown into my house about four years ago, it made a +6 degree difference in the internal temperature of the house (we heat with wood), going from about 60-62 degrees to 68 degrees. Hugely more comfortable, same amount of wood burned.
Now how to tell if you have insulation, you need to drill a few small holes through the drywall inside and look inside. You may have fiberglass, rock wool, cellulose, vermiculite, or nothing. I don't know of any way to divine what is in the wall without physically inspecting.
Daniel Holzman is online now   Reply With Quote
Old 03-23-2012, 10:56 PM   #6
Rewards Points: 1,092
Yes to the above, but a caution. The house has been "working", and if you pack in insulation where there was none AND IT IS LEAKY, you may introduce a problem. The problem may be that the exterior sheathing will now get cold and condense. Thus, you will need to ensure that air sealing is done. (PS: I did not come to this conclusion on my own. I read about it on greenbuildingadvisor.com. If you don't trust them, then don't listen.)
no wall insulation langless28 Insulation 10 01-07-2012 10:23 PM
new wall insulation question s002wjh Building & Construction 9 01-05-2012 01:57 PM
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 01:55 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
