Blown Insulation Questions. - Insulation - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 08:46 PM   #1
blown insulation questions.
Hi,
I am wanting to blow some insulation into a 2nd story bedroom. The problem is there is no access to the attic. As well, the attic is only about 3 to 4 feet high. One thought I had was if I could blow the insulation in through the vents on the roof. Of course, I would have to remove the vents. I am not sure this would work though. The only other solution I can think of would be to cut an access hole in the ceiling. Am I on the right track?
Also, I was thinking of getting the blown insulation at lowes since they provide the blower for free rental. I am curious though how far the blower throws the insulation?
thanks.
timrec is offline   Reply With Quote
Old 07-23-2012, 09:24 PM   #2
Rewards Points: 142
i don't think the vent thing would work well = very uneven distribution.
make an access port and get up there.
Fix'n it is offline   Reply With Quote
Old 07-24-2012, 05:26 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Post up a picture.
Old 07-26-2012, 07:07 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
if you don't have access you should ..... time to break out that new sawzall
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 10:11 AM
Open Eaves Soffit and new blown insulation mpierce9 Roofing/Siding 10 05-14-2011 09:51 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 01:42 PM
Basement Insulation Questions? BobR General DIY Discussions 1 09-30-2008 10:25 PM
Vapor Barrier & Blown in Insulation barbe4 Building & Construction 1 12-03-2007 09:05 PM
