Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-02-2012, 06:34 PM   #1
Blown in insulation
I just found out the previous owner put the batting in upside down(brown side upI want to have a r 38 blown fiber glass product blown in. the contractor wants to remove all the brown facing then blow in . Will this cause a problem or should I suit up and flip all of the batting(brown side down)
Hank K
osogoofy is offline   Reply With Quote
Old 10-02-2012, 06:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Blown in insulation
Where is the home?
Best bet would be to air seal the top plates first, then overblow the attic.
Vapor retarder level should be to the warm side but whether or not is even necessary depends on the location.
Old 10-03-2012, 09:37 AM   #3
Blown in insulation
I'm located in the lower southeast pa. just outside of Philly. close to delaware.
we get cold and a good amount of snow.
What do you mean by air seal the top plates?
Thanks Hank K.
Old 10-03-2012, 09:47 AM   #4
Blown in insulation
http://www.youtube.com/watch?v=8n3QC...eature=related
Old 10-03-2012, 11:21 AM   #5
Blown in insulation
Thanks you cleared that up for me,now on to the job.
Hank K.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulating your attic Bob Mariani How To Guides 2 03-01-2012 06:56 PM
Should I remove old blown insulation in exterior walls jimlane Remodeling 3 01-29-2012 07:15 PM
Blown Insulation vs. Rolled Insulation L.Stein Insulation 6 01-28-2012 12:58 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
