Blown In Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 06:39 PM   #1
Blown in insulation
I am going to blow in insulation in the attic of a brick home built in 1957. There is no room to install baffles or rafter vents. The roof does have ridge vent and 2 roof vents. Also, there is a access door to the garage ceiling area which is not insulated which could be left open for air flow. . So.....What should I do for air flow? Do I need to worry about moisture or mold if I blow in insulation with no baffles? Thanks for any help you can give!!
Randy7652 is offline   Reply With Quote
Old 06-26-2012, 07:44 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
Where is the intake air coming from?
Old 06-27-2012, 02:07 AM   #3
Rewards Points: 1,092
Yes. If you have no ventilation, it may be better to spray foam the roof itself (inside) w/ closed cell foam and open that area up (air-wise) to the rest of the house. What is up in the area you want to insulate? Any A/C, etc? (What do the rest of you think about that?)
Old 06-27-2012, 10:28 AM   #4
AGWhitehouse's Avatar
Spray foam makes me cringe...both at the $$ and the idea of EVER having to Renovate/Replace/Repair...
BUT, insulating the roof plane does alleviate some worries you (OP) seem to have...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 06-27-2012, 12:31 PM   #5
I hear ya, but it is commonly done, and what else can this cat do? Besides the concerns you mentioned, it is environmentally terrible.
Old 06-28-2012, 12:25 AM   #6
Registered User
Rewards Points: 4,912
Where are you located?
Gary
P.S. Welcome to the forums, Randy!
Old 06-30-2012, 12:02 PM   #7
Foam makes me cringe in retrofit applications in general. If you go with it make sure they follow all the recommendations from the manufacturer. Inducing no storage, finding a place to stay for a few days and removal of all the existing insulation. http://www.demilecusa.com/homeowners...l/retrofit-faq
parts is offline   Reply With Quote
Old 06-30-2012, 09:05 PM   #8
Insulation Contractor
There is also a retrofit roof vent you can have installed at the eaves. It fits under the shingles and allows air flow like a soffit vent. We have several roofing companies that use them on older homes in our area.
Comforthome is offline   Reply With Quote
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Should I remove old blown insulation in exterior walls jimlane Remodeling 3 01-29-2012 07:15 PM
Blown Insulation vs. Rolled Insulation L.Stein Insulation 6 01-28-2012 12:58 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
