-   Insulation (http://www.diychatroom.com/f103/)
-   -   Blown In Cellulose Contacting Concrete (http://www.diychatroom.com/f103/blown-cellulose-contacting-concrete-150118/)
kaalapurushha 07-13-2012 08:49 AM
Hello,
I have a 'hallway' (About 3 x 10), that is actually a projection of the floor beams over the concrete garage slab. The hallway is very cold in the winter, and I recently found out that although the wally have R-13, and I have 2 layers of R-13 fiberglass at 90 degree angles in the roof, the floor has no insulation underneath the subfloor.
I am planning on replacing the floating laminate floor with something nicer, and want to fix this at the same time. I would prefer not to remove the subfloor, and there is no other way to access this area.
I was thinking that I could drill 1" holes and dense pack cellulose in the bays, then plug the holes back up. I would use a polyurethane foam underlayment for the new floor and tape the seams.
The concrete slab has no moisture issues. We are on the top of a sandy hill, and dranage is not a problem. Is this something that I can do?
Windows on Wash 07-13-2012 12:24 PM
You will need more than a 1" hole to push the cellulose but that would work.
Dense packing is not easy with the little blowers you get from Home Depot and may require a professional blower machine.
jklingel 07-13-2012 03:45 PM
Although I am not excited about using foam, this may be a good application for it. Can you get someone to spray closed cell foam through the holes, or is that too iffy? (I'd hate to hear about your floor inching up a bit from the expanding foam. Hmmm. ???) I really don't know why, but I don't like the concept of cellulose against a slab. If I did that, I would make sure that the floor above was vapor open.
Windows on Wash 07-14-2012 10:35 AM
If he went with foam, they do have lower pressure spray foam (i.e. drip foam), but the aren't cheap.
You will be much cheaper just removing the sub-floor entirely and insulating the area with rigid/spray combination.
kaalapurushha 07-17-2012 08:51 AM
You mean using XPS and great stuff to seal the edges?
I was wary of removing the subfloor since I am not sure yet if it is nailed or screwed, and I am assuming that it may extend under the wall (There is a non load-bearing wall that makes a small closet.
I suppose I could just get a circular saw and make very straight cuts 6" or so from the wall?
Windows on Wash 07-18-2012 09:50 AM
By the time that you remove parts of the floor and pay a SPF contractor to fill the area, you can probably do just as good a job by removing some of the subfloor and insulating the area.
Cut the subfloor a few inches from the wall as you mentioned and go that route.
