Which Is Better Insulation For Gaps & Cracks In Manufactured Home? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 02:57 AM   #1
which is better insulation for gaps & cracks in manufactured home?
1. I am only looking for a top inexpensive solution to fill cracks and gaps in walls and storm windows in a rented 600 q. feet manufactured home. Therefore, which is better solution between the two below:
Mortite Caulking Cord
Dow Chemical great stuff Foam Sealant
Or does anyone have any other suggestions for any other product that will do a better job under $10-$15?
2. Can you use "great stuff Foam Sealant" outdoor? It won't crack under weather and is rain-proof right?
baby327nd is offline   Reply With Quote
Old 10-24-2011, 05:03 AM   #2
the Musigician
DangerMouse's Avatar
I'd go with the GSFoam for sure. Mortite is more for caulking windows, isn't it?
As to rain proof? Use the GSF that is closed cell and you should be fine outdoors, even open cell will be okay. Both will turn bright orange in the sun though....
DM
Old 10-24-2011, 07:00 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,204
As mentioned, most foams break down in the presence of UV light so it will begin to degrade from day one.
Old 10-24-2011, 09:17 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
How big are these cracks and gaps? ...Caulk may be the better option if they are small enough as it will hold up better outdoors... If they are large gaps, the foam would be the better choice, but perhaps you could figure out a way to cover it on the exterior?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-25-2011, 08:16 PM   #5
1 All gaps & cracks are small except one that is one inche wide and another 3 inche wide [which is a hole outdoor in a metal wall]
2. Is it possible that I can apply caulk on all gaps & cracks FIRST and than apply foam sealant on top of that?
Home Energy Audit & Spray Foam Insulation sweets Insulation 7 09-08-2011 10:45 PM
Best Insulation for Home Remodel???? psubaron Building & Construction 0 08-17-2011 11:37 AM
Cape Style Home Insulation - Kneewall edfromma Roofing/Siding 5 12-16-2009 02:07 PM
Remodel of Manufactured Home in Flagstaff JeanneP Introductions 2 11-10-2009 08:27 PM
Home Insulation sbrzez1 Building & Construction 7 02-28-2006 07:41 AM
