Best Way To Insulate The Outside Of Cement Block House? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 07:32 PM   #1
Best way to insulate the outside of cement block house?
I want to cover a portion of my cement block house with vertical siding. I plan on fastening furring strips to the block and using the highest R value foam insulation I can find. Is it better to put the foam on the outside of the strips or in between the strips. I was just thinking what a pain to deal with the over 1 1/2 inch thickness I will add to the outside of the wall if using 3/4" furring strips and 3/4" installation and then the siding. Jim
badyellowvette is offline   Reply With Quote
Old 09-22-2012, 07:50 PM   #2
Rewards Points: 12,818
Go with the 3/4.
You do know all your windows and door trim also need to be build out 3/4 right?
It would be a great time to wrap all the trim with coil stock. And add vinyl soffits.
I bend the coil so it has a nailing flange on the outsides which also keeps water from getting in behind the J moulding.
At the bottoms of the walls I'd suggest you run a band of 1 X 6 vinyl lumber with Z moulding then the siding.
That will prevent damaging the siding with the weed wacker.
Old 09-23-2012, 11:43 AM   #3
So should I put the insulation between the furring strips or over top?
Help me insulate a balloon framed carriage house... wrooster Insulation 18 01-20-2012 09:08 AM
patching holes in basement cement block wall jhiner Building & Construction 3 06-02-2010 04:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
how to remove musty odor, waterproofing a cement block handydady Building & Construction 6 09-19-2008 08:54 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
