Best Way To Hold XPS To Wall While Adhesive Dries? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 12:53 PM   #1
Best way to hold XPS to wall while adhesive dries?
Guys, I'm currently applying 2" Owens Corning Foamular 150 rigid foam to my basement walls. All the foam has been cut and dry fit and now I'm ready to attach. I purchased Loctite PL-300 foam adhesive but I'm having a hard time getting the foam board to sit tightly against the wall. My walls are poured concrete so they aren't perfectly smooth. Any ideas?
AMarkham40 is offline   Reply With Quote
Old 12-06-2012, 04:12 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
More glue and nail up some furring strips to clamp it to the wall.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 01:35 PM
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 01:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
