Best Foam Board For Knee Wall Access Doors? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 11:38 AM   #1
Best foam board for knee wall access doors?
Greetings all,
I am in the process of air sealing and improving the insulation in my attic.
I'm wondering what best to use for foam board on the access doors. The r value seems pretty low on most boards and if it is too thick the door won't open properly (think arc). So, my question is can someone recommend which foam board to use? I've seen an RMax with R9+ @ 1 1/2" but ii is intended for exterior use. Could I use this as I think three inches would be the max depth possible.
TIA
diyxer is offline   Reply With Quote
Old 07-09-2012, 11:47 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,184
Polyiso or EPS.
The Polyiso with the foil facing is great as it provides some added benefit from the radian barrier. You can stack the layers together to get you whatever thickness you need.
Old 07-09-2012, 11:52 AM   #3
Originally Posted by Windows on Wash View Post
Polyiso or EPS.
Thanks, are those brand names? What kind of R value per inch can I expect to find in these?
Sorry for the dumb questions. But every time I go to HD or Lowes I'm seeing stuff that is 2 inches thick with like r3 value. That just won't cut it.
Old 07-09-2012, 12:01 PM   #4
HD or Lowes look for a Thermax board (roughly R-6 per inch).
The Following User Says Thank You to Windows on Wash For This Useful Post:
diyxer (07-09-2012)
Deck: gap from 1st deck board to wall frankkerfoot Building & Construction 2 05-16-2012 08:49 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
