Best Attic Hatch Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 05:17 PM   #1
Best attic hatch insulation?
My attic is fully insulated except attic hatch. My (independent) energy auditor by some reason suggested to install McCoy Attic LadderMate. I'm a bit hesitating since my ceilings are not very high, and LadderMate takes another 2'' of their height. Is it really that good or there are in-attic fixes which are not worse at least. I looked at several attic covers, and still not sure how good they are... Any experience/suggestions?
mzaslavsky is offline   Reply With Quote
Old 03-16-2013, 05:56 PM   #2
you have a couple options here. do you have pulldown stairs, or is the access truly a hatch?
asinsulation is offline   Reply With Quote
Old 03-16-2013, 10:58 PM   #3
It is just pulldown stairs
Old 03-17-2013, 12:03 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,124
If its pull down stairs, you can build your own enclosure and insulate it with rigid foam or get one of the pre-built foam enclosures.
Either will work. Make sure the seams are tight, sealed, and aligned. Weatherstrip the top that fits on to the sides.
The Following User Says Thank You to Windows on Wash For This Useful Post:
mzaslavsky (03-17-2013)
Old 03-17-2013, 05:02 PM   #5
just as he said. I would recommend building it on your own though, as I have had alot of difficulty with the prefabbed boxes unless the plywood or whatever flooring around those attic stairs is in great shape.
The Following User Says Thank You to asinsulation For This Useful Post:
Old 03-17-2013, 06:30 PM   #6
Rewards Points: 6,652
Scuttles are easy, due to all you have to do, is apply foam stripping or some kind of weather stripping around the flat edge that the hatch lays on, and a layer of xps over the wood inside the frame for the lid, then a layer of batt over that, once closed, you just seal with clear silicone caulk and you are done.
Attic stairs are harder, especially if they do not have some kind of seal over the access hole above, or weather stripped around the edge when the hatch is closed.
Attic Insulation & Sealing planning fstr Insulation 7 11-19-2012 11:54 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 06:19 PM
