Bay Window Ledge - Insulation - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 10:17 PM   #1
bay window ledge
Hi All,
I have an older home with a bay window. It is not the slide in type, each window was replaced individually because of the cold air on that side of the room. It did make a difference but I still have a major problem. The ledge on the inside is wood and it looks to me like it is about an inch thick and that is all there is. On the outside it is also wood, no insulation at all. It is really cold in the winter and I don't have a clue how to fix it. I've had a few people look at it to try to come up with a solution on how to solve the problem but no one has been able to help me. Any ideas on how this can be insulated?
swhite is offline   Reply With Quote
Old 01-20-2014, 10:42 PM   #2
Registered User
Rewards Points: 4,924
Extend the trim down, set-back from original for a drip edge, add 2-4" of XPS, cover with plywood soffit, caulk perimeter against air leakage. You need to decouple the wood from the ground temps, Fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
PS. Welcome to the forums!
Old 01-21-2014, 07:22 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Great advice Gary.
Not the easiest of projects but it is the only way to get it done right.
Old 01-21-2014, 10:12 AM   #4
Rewards Points: 12,876
A picture might help to come up with some other suggestions.
There's a bunch of different ways to add on to the bottom of the window to add some insulation.
http://www.bing.com/images/search?q=...rior&FORM=IGRE
Old 01-21-2014, 01:29 PM   #5
Rewards Points: 906
I love that you use Bing.
Google is scary with the amount of information they are collecting and to be perfectly honest...I think I get better search results with Bing.
General window install questions miamicuse Windows and Doors 9 04-23-2013 09:05 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
