#1 |
batt insulation and blown in
i am redoing my kitchen. i pushed back the blown in insulation in the attic above the kitchen to redo sheetrock, add recessed lights etc. i will be putting up faced batt insulation and was wondering if its a good idea to rake/blow the blown in insulation back on top afterwards. specifically fill in the areas right around all the recessed lights (total 7) they are 5" halo's and are IC rated and the blown in is of the recycled newspaper/fire retardant type stuff.
#2 |
Moderator
Heavy cellulose insulation will compress the lighter f.g. batts, expect some loss of R-value; http://www.greenbuildingadvisor.com/...fiberglass.JPG
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#3 |
Exterior Construction
You will get some compression but you gotta cover those rafters and the cellulose is better are resisting convection.
Make sure the cans are sealed up tight and not just IC rated.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Thanks for the responses. I actually read some older posts stating the weight differences.
Do they make r30 faced rolls of insulation? I was looking at the two big box stores and it seems that faced r30 is only sold in the precut (more expensive) variety. |
#5 |
why are you using batts ? and not just blowing more cellulose ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#6 |
Well to be honesty don't know much about insulation. Trying to do my best with research. Is blown in far superior? What would be the vb? Plastic sheet under joists?
#7 | |
batt insulation and blown inQuote:
i was told it isn't needed. and that the paint is all that is needed. but, i am sure there is more to it than that. so wait for the pros to chime in.
#8 |
Moderator
You pretty much covered it! To back-up the claims; http://michaelbluejay.com/electricity/insulation.html
http://www.cellulose.org/HomeOwners/...orBarriers.php Cellulose ceiling sag; http://www.energyguide.com/library/E...SubjectID=8375 Check with local AHJ for required poly with your State Energy Code; http://www.ecohomemagazine.com/energ...rfriendly=true Gary
#9 |
1 thing i noticed with the blown cellulose = it gets in the nooks and crannies. i mean, it REALLY gets in there ! and the pro's here feel this to be a very good thing.
#10 |
any rough idea on how much a blower would be? i wouldn't not need enough to get the free blower deal. the ceiling is about 100sqft.
also on something like this: http://www.homedepot.com/Building-Ma...specifications does that imply it gives a 40sqft area a r3.7? so if i have a 100sqft and want R38 i would need roughly 25 bags of that? Last edited by langless28; 11-06-2012 at 11:47 AM. |
#11 |
Why not blow the whole attic?
Might as well upgrade the insulation in total. Be sure to air seal first.
#12 |
It already has been updated with cellulose and air sealing. I had an energy audit and took advantage of a $2k rebate and got air sealing, r38 cellulose and blown in wall insulation for about $500 out of pocket. Unfortunately I am doing the kitchen now, I opened the rafters one by one to blow the cellulose back fom the kitchen area. There was also old batt insulation previously in the attic
#13 |
Bump it up to R-50.
Can't hurt.
#14 |
Agreed. As to my question on blown in; is that how's it's calculated?
#15 |
100sf. i think i would put roxul. then pile on what cellulose you have over the top.
| Display Modes | |
| Wall Insulation - Batt vs. Blown In | mykquin | General Discussion | 7 | 11-11-2011 08:39 PM |
| Blown in insulation question? | El Gringo | Insulation | 2 | 11-11-2011 12:20 AM |
| Blown in insulation for un-insulated attic | Cubey | Insulation | 10 | 10-19-2011 08:08 PM |
| Open Eaves Soffit and new blown insulation | mpierce9 | Roofing/Siding | 10 | 05-14-2011 09:51 AM |
| Has anyone used Green Fiber blown in insulation? | pomelo | Building & Construction | 7 | 02-10-2010 08:17 AM |
