#1 |
Bathroom Insulation and Vapor Barrier
I'm remodeling a bath, upon demo I found water damage behind the tiled shower stall, located on an exterior wall corner. It seems the original big box builder didn't take the correct steps to ensure a quality job. The insulation in place had no Kraft paper, nor any plastic vapor barrier, it was unfaced insulation with green board and cement board directly attached to the studs.
Now I'm in the rebuilding process, and I keep reading conflicting information regarding insulation, and a vapor barrier for a bathroom. Conflicting Info Examples - Use both Kraft paper insulation, and a 6mil poly vapor barrier - Never use two vapor barriers next to each other, they will create a moisture trap and cause issues - Inspectors won't allow faced insulation installed, and will require kraft paper removed. I'm planning on using cement board and re-tiling, but first question, what to do about the insulation and vapor barrier. Any input regarding the correct/best method to insulate would be appreciated. Jim Last edited by jibennett; 02-17-2013 at 11:33 AM. |
#2 |
Need to water proof the tile board, that will be your vaper barrier.
| The Following User Says Thank You to joecaption For This Useful Post: | oh'mike (02-17-2013) |
#3 | |
Bathroom Insulation and Vapor BarrierQuote:
#4 |
Super Moderator
As Joe said---waterproof the face of your cement board----best insurance you can buy---if you do---then use unfaced insulation----
New members: Adding your location to your profile helps in many ways.--M-- |
#5 |
Question Oh' Mike... Do you need a vapor barrier on the entire bathroom (Ceiling, shower area, non-shower area (sink, toilet, etc))? Or does it only need to be in the shower area?
Basement Demo started Jan 2012: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Bathroom demo started Feb 2013: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Super Moderator
Waterproofing is only done on the face of the cement board in the wet areas----ceilings and other walls should use insulation with a vapor barrier-----
#7 |
Moderator
1. Where are you located?
2. Is the bathroom above/below grade? 3. Describe the exterior wall make-up... Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#8 | |
2) Above grade 2nd floor 3) Exterior: Vinyl siding, sheathing, stud/insulation Jim |
#9 |
Moderator
Find your location on the map for Zone, read:http://www.buildingscience.com/docum...commendations/
No vapor barrier/retarders in basements: http://publicecodes.cyberregs.com/ic...001_par003.htm Same with greenboard: http://publicecodes.cyberregs.com/ic...002_par013.htm Gary PS. May need to find closest city for Zone below the map in list, here; http://publicecodes.cyberregs.com/ic..._11_par002.htm
| Display Modes | |
