Bathroom Insulation Removal - Insulation - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 06:51 PM   #1
bathroom insulation removal
Hi,
I've read several of the threads dealing with insulation on some level. I am demolishing my bathroom due to constant issues with mold/mildew and very little ventilation.
Needless to say, there was mold on the drywall (no cement wallboard or moisture barrier) and the insulation looked discolored; some was black and the paper was thin.
Can I safely take the insulation myself? and replace it. I have demolished and retiled an very similar bathroom, but there was nothing like this to deal with.
thanks for the advise.
Renee
recanada is offline   Reply With Quote
Old 04-11-2013, 03:39 PM   #2
Rewards Points: 186
This is more of a water proofing question than anything else. It seems you already know to put a waterproofing layer, so to answer your insulation question, yes, just put back as much as you reasonably fit in there (R-13 probably if it's a wall). But just make sure you are aware where the water was coming from if it's an outside wall, it could be coming from the outside too. In our case the water source was the window that wasn't sealed properly (we replaced the window which was fairly cheap and easy, and caulked it properly this time). We had other water damage from the shower, and I'll detail what we did for a waterproofing solution.
You need a water proofing membrane behind the tile. For the walls use something like Schluter Kerdi. For the floor (if it's a tile floor not bath tub) use Kerdi Ditra.
you basically have to rip out the tile and durock, and put them back in this order.
Stud Wall -> Durock -> Kerdi waterproofing membrane -> Tile
you put a layer of thinset between the Durock and Kerdi waterproofing membrane, and then tile like you normally would.
http://www.schluter.com/2080.aspx
Hope that helps
Ocelaris is offline   Reply With Quote
Old 04-11-2013, 10:42 PM   #3
Rewards Points: 13,296
Why is there no ventalation?
Going to have the same issure if you do not add some.
Got some pictures?
Old house? No sheathing or house wrap?
Weird little bathroom insulation questions Grant2k Building & Construction 2 11-24-2012 06:27 PM
Insulation removal wenku Insulation 1 01-11-2012 06:25 PM
Bathroom Ceiling Insulation trophywalleye Insulation 6 03-13-2011 03:39 PM
Any warnings for insulation in a bathroom? jayp Building & Construction 11 08-03-2008 10:35 PM
removal of old hard bathroom caulk pop2pop General DIY Discussions 1 02-25-2005 02:11 AM
