Bathroom Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 12:32 PM   #1
NEWBIE
Bathroom insulation
im gutting my entire bathroom down to the studs. is there any special type of insulation that i should put behind the walls because currently there is none???
tia
D-DoT is offline   Reply With Quote
Old 10-30-2011, 03:53 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,676
Where is the home located? You will need to know if you require a vapor barrier.
In terms of insulation, you will want to put as high an R-value that you can get in the walls to avoid any condensation issues.
Make sure the bathroom is vented to outside properly as well to control humidity.
Old 10-30-2011, 04:56 PM   #3
NEWBIE
I'm located in long island ny. And how do I know if the bathroom is vented properly?
Old 10-31-2011, 08:35 PM   #4
You need to get the moisture (i.e. steam) out of the bathroom. This is most effectively done via a mechanical fan.
Old 10-31-2011, 08:47 PM   #5
NEWBIE
So ur saying I need a fan cut out thru the wall that sucks the air outside? And websites u can recommend so I can see this?
Old 11-02-2011, 01:01 AM   #6
Should be vented up, through the attic to the roofline.
http://www.thisoldhouse.com/toh/how-...689843,00.html
Old 11-02-2011, 04:50 PM   #7
NEWBIE
ok thanks i will look into this.
Does any one know of a program or website i can use to put in the raw dimensions of my bathroom and kinda get a visual of what i want to do? kinda like move objects around to pre plan???
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 09:54 PM
Cold bathroom toeey1 Roofing/Siding 5 02-10-2010 07:29 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
19" spaced joists - foil faced insulation? CWorth Remodeling 3 03-21-2009 12:26 PM
Any warnings for insulation in a bathroom? jayp Building & Construction 11 08-03-2008 09:35 PM
