-   Insulation (http://www.diychatroom.com/f103/)
-   -   Bathroom insulation (http://www.diychatroom.com/f103/bathroom-insulation-121813/)
D-DoT 10-30-2011 01:32 PM
Bathroom insulation
im gutting my entire bathroom down to the studs. is there any special type of insulation that i should put behind the walls because currently there is none???
tia
Windows on Wash 10-30-2011 04:53 PM
Where is the home located? You will need to know if you require a vapor barrier.
In terms of insulation, you will want to put as high an R-value that you can get in the walls to avoid any condensation issues.
Make sure the bathroom is vented to outside properly as well to control humidity.
D-DoT 10-30-2011 05:56 PM
I'm located in long island ny. And how do I know if the bathroom is vented properly?
Windows on Wash 10-31-2011 09:35 PM
You need to get the moisture (i.e. steam) out of the bathroom. This is most effectively done via a mechanical fan.
D-DoT 10-31-2011 09:47 PM
So ur saying I need a fan cut out thru the wall that sucks the air outside? And websites u can recommend so I can see this?
Windows on Wash 11-02-2011 02:01 AM
Should be vented up, through the attic to the roofline.
http://www.thisoldhouse.com/toh/how-...689843,00.html
D-DoT 11-02-2011 05:50 PM
ok thanks i will look into this.
Does any one know of a program or website i can use to put in the raw dimensions of my bathroom and kinda get a visual of what i want to do? kinda like move objects around to pre plan???
