Bathroom Ceiling Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 11:32 AM   #1
Rewards Points: 45
In my main bathroom renovation, I just insulated, vapor barriered, and installed a bathroom fan in the ceiling.
When I insulated the ceiling I only had a few batts of the grey/green moisture/mold proof insulation R20, and the rest the pink R12. Near the wall above the shower is the R12 pink insulation with more R20 above it.
I am just about to drywall the ceiling, however I'm wondering if I should pull it all down and start over insulating it all with the grey/green moisture/mold proof insulation.
Am I crazy to do it all again? Is the non-moisture/mold proof insulation necessary?
trophywalleye is offline   Reply With Quote
Old 03-12-2011, 01:11 PM   #2
Registered User
Rewards Points: 526
Not if using the plastic v.b. I'd air seal the fan box for leaks that could deposit moisture in the fiberglass; http://www.google.com/url?sa=t&sourc...O842EQ&cad=rja
Moving you to our brand new "Insulation" section.
Gary
Old 03-12-2011, 02:03 PM   #3
Rewards Points: 45
Re:
Thanks GBR,
Please see my bathroom exhaust fan installation pdf attachment.
If you look at figure 9 there are slots in the housing for torsion spring attachments used for the fan cover. The slots are small, however still a path for moisture to travel from in the bathroom and into the attic or in between the vapor barrier and insulation.
Is this normal??
My pink insulation batts are right by the fan and I don't want to get into any mold of moisture issues.
I assume as long as the fan is running this slot doesn't matter as all of the air is pulled through the fan.
The link GBR posted is useful, but I'm wondering how many people actually seal the bathroom fan in a rigid foam box??
If this is the case I will have to pull the vapor barrier and insulation down as it's extremely difficult to work from the attic. I've done this a few times (shallow pitched roof) and no work boards.
Any advise?
Josh
Old 03-12-2011, 02:06 PM   #4
Rewards Points: 45
PDF Link
http://www.airkinglimited.com/instructions/BFQIO.pdf
Old 03-12-2011, 02:13 PM   #5
Registered User
Rewards Points: 526
Just like mine! I added some backer rod poly around the wires, on the cover so no air leaks there when its closed, glued them on.
Gary
Old 03-13-2011, 09:54 AM   #6
Rewards Points: 45
Hi GBR, could you please clarify what you mean. You used the backer rod poly (or foam pipes) around the torsion springs? Because I don't understand how that fully seals the slot.
Also, do you have this rigid foam box around you exhaust fan mentioned in that pdf you posted? Every video and picture I see online doesn't have that, even though it may be superior.
Old 03-13-2011, 02:39 PM   #7
Registered User
Rewards Points: 526
My first fan, I glued b.r. to the slot sides, one on each side. The wires poke between the b.r. pieces into the slots. Last cover contacted the fan frame, different than before. If you don't cover the slots, not that big of a deal, you would be sucking attic air while fan is on, letting small amount of bathroom air to attic while off.
Gary
Tar bleeding through paint on bathroom ceiling dwoloz Painting 5 08-15-2010 08:10 PM
Paint Bathroom Ceiling questions? Hypochondriac Painting 5 08-15-2010 04:51 AM
Bathroom ceiling StevePax Drywall & Plaster 4 01-03-2010 12:32 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Best primer for bathroom ceiling dbldee20 Painting 11 01-06-2009 03:25 PM
