Basement XPS Foam And Wiring? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 10:29 AM   #1
Basement XPS Foam and Wiring?
I have been researching this and I would like to put xps foam board on basement walls then furring strips, can I just wire up the electrical then put drywall on top?
Cobra397 is offline   Reply With Quote
Old 04-04-2013, 11:27 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
In theory, yes.
All the wires need to be protected where they cross the furring strips with nail plates.
Most folks prefer to frame out the space, add additional insulation, and go that route. It makes for a tighter and more insulated shell as well as being easier to pull wire and set switches and other items.
Old 04-04-2013, 11:31 AM   #3
Thats what I have been reading but on one wall I am very limited on space and would prefer to keep as much of my room as possible. This is a small room and a half basement. Approx. 18 x20 with tall ceilings. I would be using the 2 inch foam so R 10 I think.
I live in southern Tn right on the Alabama boarder area. I just want to add two plugs per wall and a light switch at the bottom of the stairs. I was worried about the heat from wires and keeping it to code. Anyone else done it this way? I could always use thicker furring strips for more room behind drywall?
Old 04-04-2013, 02:09 PM   #4
also, I have a door that leads outside to a stairway. The door hinges are rigth next the corner of the outside wall? I cant move the door farther in or cut the opening more. The only option I see is to use 2 inch and drywall then cut the down down a few inches to make it fit.
If I can I was just going to foam board wall then run wiring and drywall over top?
Just looking for others who have done it this way.
Old 04-04-2013, 09:18 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
You'll want to check your local codes on that. Around here, that method only flies with paneling, no-go with Sheetrock.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-05-2013, 09:56 AM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
If you mean run the electrical on the outside of the drywall ( toward the interior) that is a valid option as well.
www.HomeSealed.com
Old 04-09-2013, 09:11 AM   #7
No I was wanting to do XPS, Furring strips, Wiring, Drywall. I am still learning so please be patient with me. One wall is the main problem as it is tight againts the outside door and no matter what I will have to get a smaller door to fit the opening.
I was just hoping to keep the walls as thin as possible. If it is possible. Anyone else done XPS then some type of covering with wiring?
Old 04-09-2013, 09:46 AM   #8
Rewards Points: 878
There are basement wall systems that work just as you have detailed out. Most of them have wiring chases built into the foam for running the wires.
Doing it off the shelf like you are proposing is fine, but it take a bit more engineering on your end of things.
Old 04-09-2013, 09:21 PM   #9
Thread killer
Rewards Points: 272
Where I live the electrical has to be 1.5 inches away from the finished surface for the whole run. If it isn't, I need to protect it in some way, with nail plates or conduit, etc. I'm not an electrician but, if I understand what you're planning, the wiring will be behind the 1/2 inch of drywall?
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 04-10-2013, 08:50 AM   #10
yes, I have done some reading and I believe I saw where a guy used 2x3 furring strips to give him some more space. I would not mind running it through conduit. I know I need to check with local codes first but just trying to get my ideas together.
I could frame out a 2x4 wall but one wall really needs to be just the xps then drywall. I am not planning to do this soon but sometime over the summer would be nice. Thank you all for your input and help.
Basement wall insulation / remodel question Chokingdogs Insulation 2 03-14-2013 01:26 AM
basement insulation fred54 Insulation 7 08-05-2012 05:12 PM
correct order to finish basement diy001 Remodeling 2 03-09-2012 02:04 PM
Is spray foam insulation that much better than fiberglass? HautingLu General DIY Discussions 18 09-21-2010 07:36 PM
Basement - Wiring & Insulation heybrady Electrical 8 03-10-2008 10:37 PM
