Basement Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 08:16 AM   #1
basement walls
whats steps are necessary before drywall. foam board? vapor barrier? insulation?
basement in south central PA, concrete floor, superior walls.
Dantro is offline   Reply With Quote
Old 03-30-2013, 08:30 AM   #2
Rewards Points: 13,260
Might was to try and use the search funtion on this site. There's at least 1000 replys and suggestion on this one subject.
Adding your location to your profile will be a big help on questions like this.
Just go to Quick links to edit.
Old 03-30-2013, 10:22 AM   #3
i've found that i want to go styrofoam not fiberglass. my next question would be , vapor barrier, needed? where?
Old 03-30-2013, 11:04 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
Looks like you have XPS against the walls already in this case.
Seal up the rim joist area and spray foam/seal all the gaps.
after that you can insulate with standard batting (Mineral wool is preferable) and drywall.
Be sure to drywall according to ADA.
Happy Easter!
Old 03-30-2013, 11:55 AM   #5
ccarlisle's Avatar
well, as WoW points out, a few minor things and you're good to go! But your next question is a bit more "open" for discussion - the one about vapor barriers.
IMO, and from where you are geographically, there may not be a need for a vapour retarder nor a vapor barrier unless that is if you have a serious humidity problem in that basement of yours. If not, then I'd opt for a mold and mildew-resistant insulation (it looks as though you have 3-4 inches of space between the studs) - such as 'Roxul' - then drywall with mold and mildew-resistant blueboard, then prime and paint with a latex paint.
That should be all you need...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-30-2013, 07:24 PM   #6
Registered User
Rewards Points: 5,212
I'd check your paper work on the system, if available. That panel comes in R-5 or R-12.5. (From the "Homeowner guide"; http://www.superiorwalls.com/tech_resources) For your location, you need the R-12.5. You need to know which wall you have. You can also just measure the stud depth (concrete stud depth plus the 1" SPF ans steel stud; minus the 1-3/4" concrete facing). http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja
I agree XPS (as their B.G. says= to cover them (liability) against condensation) in the cavities because of your location AND the thermal bridging of the concrete studs (.08 per in.) with open-cell SPF used on them 1" thick (3.6 per in.) at 16"on-center. What is the measurement?
Gary
Old 03-31-2013, 08:05 PM   #7
Registered User
An added thought, you may need special (steel stud) screws for the drywall because of the steel studs and the added 1/2" plywood strips (that won't hold much, because of their thickness and also depending on how securely they were fastened). Air-tight the drywall, as said already; http://www.buildingscience.com/docum...wall-approach/
http://www.buildingscience.com/docum...l_seal_rev.pdf
Gary
Painting tricky Basement walls. What paint should I use? tw1208 Painting 1 10-12-2012 09:07 PM
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 01:36 PM
What to do with basement walls. RR. Remodeling 3 02-20-2012 07:49 PM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 01:44 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 04:42 PM
