Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-14-2012, 03:33 PM   #1
DIY Expert
Basement Wall Insulation Question
Ok so I'm remodeling my basement and trying to do it the right way instead of the way the previous owner did.
So far, I have 2" EPS on the concrete block wall, 2x4 PT wood for a plate under 20 gauge metal track with metal studs, all tapcon'd to the concrete floor. Now where I'm confused is, if I should put unfaced batts between the studs or not. I've had moisture problems in the past but I think the interior drains and sump pump will resolve the majority of the issues.
I usually don't put fiberglass batts anywhere in a basement due to it holding moisture/molding but I don't see the 2" EPS foam board really providing much R value.
Any suggestions?
doublejz is offline   Reply With Quote
Old 12-14-2012, 04:41 PM   #2
There's well over 2000 post on this one subject. Look at the top of the page and go to search.
Old 12-17-2012, 01:38 AM   #3
if the eps is well sealed, it is doing what is stated for its density, which is better than any wall can do, regardless of insulation type; the wood will lower the overall wall r value. you can always jam more eps between the studs, leaving a gap large enough for Great Stuff to fill. or, use roxul insulation. it is superior to fg in a couple of ways.
basement insulation question pete126 Insulation 3 09-10-2012 07:39 AM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 02:55 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 10:02 PM
