Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 02-06-2013, 10:44 PM   #1
Basement wall insulation
I am finishing a basement with a 4 foot concrete wall with a wood framed and insulated wall on top. I am wondering the best way to insulate this, and if vapour barrier is needed. The top section is insulated with batt insulation and poly vapour barrier on the warm (inside) of the insulation. I am in canada where it gets very cold in winter and quite warm in summer. This is my idea. I will line the bottom part with a thin eps rigid foam, then frame with 2x4 in front of that. Creating a ledge around the basement. Then put batt insulation in between studs. Then vapour barrier tied into the poly above and then sheet rock both bottom and top part of wall. Does this sound like it will work? Thanks in advance for any advice.
Trevor.
T-revb is offline   Reply With Quote
Old 02-06-2013, 10:52 PM   #2
Go to the search funtion and check it out. This question has beeen asked and ansewered several thousand times.
Old 02-06-2013, 11:06 PM   #3
Thanks for the helpful tip. I have been looking through past posts, but I find they are talking about full cement basements. I guess my concern since the top half of my basement is above ground and wood and is insulated and has vapour barrier is if I need to tie the bottom into that vapour barrier? Or if I use rigid foam against the cement does it even need any vapour barrier?
Old 02-06-2013, 11:32 PM   #4
Possibly I am not putting in the proper key words for the search. Does this type of basement have a certain name I should be searching under?
Trevor
Old 02-09-2013, 10:17 PM   #5
Moderator
Here are some local tests; ftp://ftp.cmhc-schl.gc.ca/chic-ccdh/..._Web_sept5.pdf
Canada test by BSC: http://www.buildingscience.com/docum...ent-insulation
Between fig.9 and photo 4, foam thickness; http://www.buildingscience.com/docum...Lstiburek_2004
Where are you located?
Gary
PS. welcome to the forums!
Clothes taking longer to dry?
Old 02-10-2013, 12:30 AM   #6
Gary
Thanks for all the info. I am located in Saskatoon Saskatchewan. Our climate would be similar to the results in Edmonton in the tests. From asking around, fibre glass batt insulation with interior poly for a vapour barrier seems to be the most common practice in my area. I think I will go that route with a thin (1/2") expanded foam also right against the concrete. I think this would help as it would keep the batts and wood frame walls from contacting the cement, and may help keep moisture from possible inward drying of the concrete from getting to the batt insulation and wood. And since this type of foam is not a vapour barrier I believe it would eliminate the problems associated with a double vapour barrier.
Trevor
Old 02-19-2013, 11:31 AM   #7
HI T-revb, did you find an answer? I am in the exact same situation, I'm in NB, 42" concrete wall with 2x6 knee wall on top. I have no insulation at all yet. Just starting a major reno of this property.
Rob
mani1147 is offline   Reply With Quote
Basement Wall Insulation Question Pigonahog Insulation 10 01-26-2013 02:55 AM
Basement Insulation (I can't use XPS) AllGoNoShow Insulation 7 11-11-2012 11:13 AM
Vapor barrier on basement wall gregsenne Insulation 4 10-13-2012 12:27 AM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
