Basement Wall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 02:51 PM   #1
Basement wall insulation
Using glued 2" rigid foam(blue) in between the poured concrete wall and my stud framing... Is this correct? Any vapor barrier needed?
stoked91 is offline   Reply With Quote
Old 01-13-2013, 02:52 PM   #2
Also, do I need to insulate any more than just the rigid foam layer... Do I need to roxul the stud walls?
Old 01-13-2013, 02:54 PM   #3
Rewards Points: 13,444
Just go up to the search funtion, there's well over 2000 post on this one subject.
Old 01-13-2013, 04:00 PM   #4
Registered User
Rewards Points: 5,460
No vapor barrier per BSC: http://www.buildingscience.com/docum...study-analysis
Though you may need to control the relative humidity down there, part of the year. Using 16*F http://www.eldoradocountyweather.com...e2/London.html
http://www.metric-conversions.org/te...fahrenheit.htm for your average of three coldest months; Dec.-Feb. with 70*F in room, R-10 and R-15 (Roxul) gives your f.b. inside temp. of 38*F or 31% RH. With R-15/15 = 42*F @ 38%RH.
Gary
Basement Insulation (I can't use XPS) AllGoNoShow Insulation 7 11-11-2012 10:13 AM
Vapor barrier on basement wall gregsenne Insulation 4 10-12-2012 11:27 PM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 12:15 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
