-   Insulation (http://www.diychatroom.com/f103/)
-   -   Basement wall insulation (http://www.diychatroom.com/f103/basement-wall-insulation-169014/)
stoked91 01-13-2013 02:51 PM
Using glued 2" rigid foam(blue) in between the poured concrete wall and my stud framing... Is this correct? Any vapor barrier needed?
stoked91 01-13-2013 02:52 PM
Also, do I need to insulate any more than just the rigid foam layer... Do I need to roxul the stud walls?
joecaption 01-13-2013 02:54 PM
Just go up to the search funtion, there's well over 2000 post on this one subject.
Gary in WA 01-13-2013 04:00 PM
No vapor barrier per BSC: http://www.buildingscience.com/docum...study-analysis
Though you may need to control the relative humidity down there, part of the year. Using 16*F http://www.eldoradocountyweather.com...e2/London.html
http://www.metric-conversions.org/te...fahrenheit.htm for your average of three coldest months; Dec.-Feb. with 70*F in room, R-10 and R-15 (Roxul) gives your f.b. inside temp. of 38*F or 31% RH. With R-15/15 = 42*F @ 38%RH.
Gary
