Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-30-2012, 02:23 PM   #1
Basement wall insulation
I live in MA and am finishing half my basement. I plan on heating it with electric baseboard. I have 1 inch foam board secured to cement walls. The framing sits about 7 inches from wall due to sewer pipe. Do i need to insulate the 2x4 walls ? If so what type of batting ? What type on the interior walls ?
bsherman is offline   Reply With Quote
Old 10-30-2012, 02:28 PM   #2
Exterior Construction
Windows on Wash's Avatar
It would be best to insulate the space.
Any type of batt insulation is fine in this case to the proper depth.
Batts are not great on the walls by themselves but if you are referring to overtop of the foam, again, anything works.
Make sure they are unfaced.
Old 10-31-2012, 11:41 AM   #3
Moderator
The batts should really be directly touching the foamboard to eliminate any conductive loops; http://joneakes.com/jons-fixit-database/743
As per code, the frame wall/cavity behind should be fire-stopped every 10' horizontally; http://publicecodes.citation.com/ico...002_par018.htm
ADA the drywall, to stop room air from getting to the concrete wall; http://www.buildingscience.com/docum...wall-approach/
Remember the rim joists; http://www.buildingscience.com/docum...l_seal_rev.pdf
For your location; if near Boston- 1" f.b. leaves the inside f.b. at 39* on your coldest days in winter with only 32% RH in the room. 1-1/2" f.b. = 57%RH at 70*, much safer against condensation there. If near Worcester- 1" f.b. = 24%RH, 1-1/2" f.b. = 49%RH.
Gary
PS. welcome to the forums!
Clothes taking longer to dry?
Basement Insulation (I can't use XPS) AllGoNoShow Insulation 7 11-11-2012 11:13 AM
Vapor barrier on basement wall gregsenne Insulation 4 10-13-2012 12:27 AM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
