-   Insulation (http://www.diychatroom.com/f103/)
-   -   Basement wall insulation (http://www.diychatroom.com/f103/basement-wall-insulation-161635/)
bsherman 10-30-2012 01:23 PM
I live in MA and am finishing half my basement. I plan on heating it with electric baseboard. I have 1 inch foam board secured to cement walls. The framing sits about 7 inches from wall due to sewer pipe. Do i need to insulate the 2x4 walls ? If so what type of batting ? What type on the interior walls ?
Windows on Wash 10-30-2012 01:28 PM
It would be best to insulate the space.
Any type of batt insulation is fine in this case to the proper depth.
Batts are not great on the walls by themselves but if you are referring to overtop of the foam, again, anything works.
Make sure they are unfaced.
Gary in WA 10-31-2012 10:41 AM
The batts should really be directly touching the foamboard to eliminate any conductive loops; http://joneakes.com/jons-fixit-database/743
As per code, the frame wall/cavity behind should be fire-stopped every 10' horizontally; http://publicecodes.citation.com/ico...002_par018.htm
ADA the drywall, to stop room air from getting to the concrete wall; http://www.buildingscience.com/docum...wall-approach/
Remember the rim joists; http://www.buildingscience.com/docum...l_seal_rev.pdf
For your location; if near Boston- 1" f.b. leaves the inside f.b. at 39* on your coldest days in winter with only 32% RH in the room. 1-1/2" f.b. = 57%RH at 70*, much safer against condensation there. If near Worcester- 1" f.b. = 24%RH, 1-1/2" f.b. = 49%RH.
Gary
PS. welcome to the forums!
