Basement Wall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 06:52 PM   #1
I am looking to insulate 8" poured concrete walls in my basement. They're about 1/4 above grade and 3/4 below grade. The walls are out of plumb and I will have to construct a 2x4 wall and will fill it with bat insulation for an achieved R value of hopefully 13.
How can you guarantee that the fiberglass stuff won't soak and have problems with moisture/mold? We don't live in a very wet climate here in Montana and yet I have heard several times that one needs to first create a reliable moisture barrier, such as 1.5" XPS sheeting.
Since the XPS sheeting will cost additional space and a considerable amount of money, I hope that I can get around having to install it. But obviously, if there's a risk of a water problem, it'll have to get done
Thanks all!
snucky is offline   Reply With Quote
Old 02-16-2012, 03:31 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
The short answer is that you can't.
Putting an XPS skin combined with a stud wall and fiberglass is a much better option.
Old 02-16-2012, 03:32 PM   #3
thanks, that's sort of what I was thinking. Is there a minimum width for the XPS board? Would 3/4" suffice?
Also, should I leave an airgap between the XPS and the 2x4 wall?
Old 02-16-2012, 07:51 PM   #4
1" is preferred.
No air gap. Use the framing to brace and hold the foam in place.
Old 02-16-2012, 11:07 PM   #5
Registered User
Rewards Points: 5,236
Compare your location to MN (similar), use the 2" foamboard, you don't want less as you are in Zone 6, Table 5.1: http://www.buildingfoundation.umn.ed...timum-main.htm
Page 59, Fig. 41: http://www.buildingscience.com/docum...study-analysis
You really need to compare the wall insulation with the wetness associated.
Gary
Old 02-17-2012, 09:21 AM   #6
thanks guys! We live in a 4b zone and not a lot of soaking going on very often. Besides the snow melt, May - June usually sees frequent rain. Beyond that, air is practically always dry here.
If using the 2", do I still need the bat insulation in the 2x4 stud wall? Or could I use a skinnier method of framing and save some room space?
Thanks!!!
Old 02-17-2012, 03:34 PM   #7
Rewards Points: 150
Thanks!!!
You'll need R-13 for basement, IIRC 1" xps will give you an R-3. ( tape all joints ) Then throw in some basic r-13 insulation rolls on top of that.
Personally, I wouldnt even consider going anything less then a 2x4 wall. You'll need room to run electric / plumbing / whatever. They'll be easier to work with and install over anything skinnier IMo
alecmcmahon is offline   Reply With Quote
Old 02-17-2012, 03:36 PM   #8
Rewards Points: 150
edit, misread - thought you meant skinnier framing.
Old 02-17-2012, 04:40 PM   #9
Registered User
Montana the State is:
5A Worth 5A Passaic 5A Dutchess 4A Barry 5A Macon 4A Wright 4A Salem 5A Erie 4A Barton 4A Madison 5A Somerset 6A Essex 4A Bates 4A Maries
Montana
6B (all)
From: http://publicecodes.citation.com/ico...001_par001.htm
Your insulation requirements: http://publicecodes.citation.com/ico..._11_sec002.htm
You could go with strapping on the foamboard, remember to check with your local AHJ for the possible fire-stopping every 10’ lineally along the wall. http://publicecodes.citation.com/ico...002_par031.htm
The basement foamboard thickness is based on temperature per location. Reducing the thickness is fine as long as you control the basement humidity, pp. 10: http://www.buildingscience.com/docum...lation-systems
Gary
Old 02-18-2012, 04:44 PM   #10
besides achieving a sufficient R value, I also am looking to compensate the out-of-plumbness of the walls. Over the whole 8' they're about 1-1/2" to 2" out of plumb. Here's what I think I'll go with
a) Foam board airtight against foundation wall to create a moisture barrier and some insulation
b) no air gap
c) 2x4 studs with R-13 bat insulation to achieve plumb walls and convenient space for wiring
the question is: What's the minimum thickness of the foam board that will create a moisture barrier. People in this thread seem to indicate that's 1"?
Old 02-20-2012, 09:15 AM   #11
hybrid
Snucky, I did a hybrid combo, foil faced foam above grade, hi density open cell below grade. Sealed all joints and corners with spray foam and tape. The idea being the wall can still breath upwards to allow humidity to vent above grade. (When completed No VB will be used behind drywall).
Then aligned my studs inside and used Roxul R13.5 rock wool which is not affected by moisture... discovered this method on buildingscience.com site.
Be sure to check and seal and insulate your RIM joist and plate thoroughly before you start the walls. This is the biggest heat loss zone in most homes. I sealed my bays individually and insulated to R25+
Chemist1961 is offline   Reply With Quote
Tags
basement , concrete , insulation
Load bearing basement wall? hyunelan2 Building & Construction 9 04-24-2012 12:36 AM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Townhouse basement insulation benb Building & Construction 0 02-15-2011 10:32 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
