Basement Vapour Barrier Issue. - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-26-2013, 11:33 AM   #16
no vapor barrier below grade!
buildingscience is a good resource - basement finishes with vapor barriers below grade are failing. the water isn't condensing necessarily because of leaks in the vapor barrier, the water can be coming through the concrete from the soil outside, because that's what concrete does. Making the wall airtight will just make the problem worse. new construction is adding foam on the outside of the foundation wall before backfill.
you have to get that vapor barrier out of there. the rigid foam is semi-permeable, which is recommended to be glued directly on the concrete, then framed out with fiberglass (no vapor barrier).
laser_jock is offline   Reply With Quote
Tags
basement , carpentry , insulation , vapor barrier
Basement Subfloor - vapour barrier dodge1930 Flooring 0 04-17-2012 02:20 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 01:44 PM
Finished Basement - Ohio - Moisture and Vapor Barrier cheddarthief Building & Construction 1 03-08-2011 01:19 AM
Is it ok to put vapor barrier first, when insulating basement? Red Squirrel Building & Construction 10 01-15-2011 04:33 PM
Vapour barrier and XPS: Continuing Previous Owner's Rennovation interdit_450 Building & Construction 9 05-04-2010 12:59 PM
