#1 |
Basement Vapour barrier issue.
First time poster here.
I recently purchased a home (in August) and performed a complete interior renovation. Now I am into the basement and have an issue I'd love some feedback on. There is a finished room in my basement that covers two exterior walls (28' and 12', all other concrete walls were exposed). The basement walls in question are famed (with 2x4 studs) 1" away from the concrete with the top 4' insulated with R12, covered with vapor barrier. The finishing is 4' of tongue and groove pine on the botton and 3' of drywall on top. The Problem: the vapour barrier is trapping moister in the wall and there was a small mold/mildew issue in the corner of the room, i kicked a hole in the wall (the 12' portion is all drywall, hole is approx 2'X2') and it was soaked, but dried up in a few days because of the new air movement. Solutions: I was wondering if installing a few grills along the bottom of the wall (4" hole saw through the pine, penetrating the vapour barrier) would allow enough air flow to solve the moisture issue.. thoughts? hoping I do not have to strip the wall down to the studs just to remove vapour barrier. FYI the portion of the basement i finished i glued foam to the foundation, framed with 2X4, batted entire cavity with R12, no vapour and drywalled. |
#2 |
10 views, but no replies.. c'mon guys!!
#3 |
Super Moderator
Yes,sir---
The best authorities on insulation--particularly Canadian--are at work---and will catch this when they get home--- I'll add my two cents--(two nickles in Canada)--Add several return air grills to allow some circulation of air behind the walls---on the new section--I'll wait till GBR--Home Sealed or Windows on Wash get home from work--- There are others that have knowledge---so you may get an answer right away----Mike--
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | EasternCanadian (12-14-2012) |
#4 |
Ah yes, I like to work 4 10 hour days.. or 4 12's.. I assume everybody has the same weekend as i do hahah
Thx for the input. Another possibility is to carefully remove the bottom 4 feet of tongue and groove pine and install it again after removing the poly. |
#5 |
Super Moderator
That would help---I see Home Sealed is answering questions---I hope he has time and sees this---Mike----
#6 |
Exterior Construction
Lets assume that you don't have a bulk moisture infiltration (i.e. foundation issue) at this juncture. Grading and foundation condition (cracks, coating, drainage, etc) should be checked but if they are good lets move on to the more likely issue.
Warm moist air + cold concrete = condensation and moisture Best bet is to seal up the bands with rigid foam/sealant combo or with CC SPF of at least 2-3". Pull down the walls and put rigid insulation on the walls. Insulated the stud bays and don't use a vapor barrier (my opinion). Drywall and make sure the drywall is airtight as a drum.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Windows on Wash For This Useful Post: | EasternCanadian (12-15-2012) |
#7 |
Windows on Wash:
The portion of the basement I finished was exactly how you suggested.. 1" rigid foam glued with PL 300 tuck taped all seams, 2X4 framing with R12 then drywall. I suppose the best way is to strip the walls in the "old" area, I was hoping to find a "half hour - low cost" solution ha. |
#8 |
No such luck my friend.
Tear it down and do it right.
#9 |
That's what I figured.. Was hoping to be convinced otherwise.
| The Following User Says Thank You to EasternCanadian For This Useful Post: | Windows on Wash (12-14-2012) |
#10 | |
Basement Vapour barrier issue.Quote:
You probably knew the answer before you posted it. In theory you could make it airtight and try that but that is a pretty impossible proposition with T&G.
#11 |
Moderator
I also recommend foamboard because it is moisture tolerant without loss of R-value when wet; http://archive.nrc-cnrc.gc.ca/eng/ib...ling-heat.html
Depends on your location, season and indoor/outdoor humidity if poly v.b. will work or not. The condensed version: http://www.buildingscience.com/docum...ent-insulation The extended version, complete with "double" poly layers: ftp://ftp.cmhc-schl.gc.ca/chic-ccdh/..._Web_sept5.pdf pp. 33-55 is note-worthy. Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | EasternCanadian (12-15-2012) |
#12 | |
Thanks for the input. I agree 100% with your method of finishing a basement, NO vapor barrier and HAVING rigid foam glued to the concrete are the two "non-negotiable" procedures in my opinion. I like to insulate the entire stud bay with R12 in a 2X4 wall.. I know guys that do R20 in 2X6... or either of these with only batting the top 4'. I have one final question because you seem very knowledgeable. In the 'new' section I finished I Insulated the rim joist with a double layer of R12 on top of tightly cut pieces of rigid foam. I have yet to poly/acoustical the rim joist. I am intending of sealing the poly with acoustical to the top of rigid foam (maybe an inch or sow down the face) and all around the top and side of the cavity as usual.. thoughts or suggestions? |
#13 |
Don't both with the poly.
Just spray foam or seal it with caulking. Seal the connection between the sill plate and the poured wall as well.
#14 | |
#15 |
Rigid foam or CC SPF.
| Tags |
basement, carpentry, insulation, vapor barrier ![]() |
| Display Modes | |
| Basement Subfloor - vapour barrier | dodge1930 | Flooring | 0 | 04-17-2012 02:20 PM |
| how to reduce mositure issue on basement? | diy001 | Building & Construction | 0 | 10-28-2011 01:44 PM |
| Finished Basement - Ohio - Moisture and Vapor Barrier | cheddarthief | Building & Construction | 1 | 03-08-2011 01:19 AM |
| Is it ok to put vapor barrier first, when insulating basement? | Red Squirrel | Building & Construction | 10 | 01-15-2011 04:33 PM |
| Vapour barrier and XPS: Continuing Previous Owner's Rennovation | interdit_450 | Building & Construction | 9 | 05-04-2010 12:59 PM |
