Basement Rads Problem - Insulation - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 01:57 PM   #1
Basement rads problem
My rads are right up against the cinderblock exterior walls, and I'm about to have the walls insulated and drywalled. How is that done when the rads are right up against the wall?
Nikki Dobrzansk is offline   Reply With Quote
Old 02-06-2012, 02:20 PM   #2
Rewards Points: 14,026
Electric, steam, hot water?
If the electic just shut off the breakers and disconnect them.
Old 02-07-2012, 06:58 AM   #3
Rewards Points: 960
You have to move the walls back away from the rads.
cleveman is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
mike - Radon problem in basement ggogmo1 Building & Construction 21 06-15-2011 06:21 PM
Basement Window Well Problem TonyTeso Building & Construction 4 03-20-2011 05:21 PM
Basement Shower Problem carolfleming Flooring 1 03-17-2011 07:17 PM
Is having a sump pump an indication that the basement has a flooding problem? MCK Plumbing 7 08-24-2009 08:57 AM
