Basement Open Truss Soffit,Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Old 05-26-2013, 06:36 PM   #1
Rewards Points: 89
Finishing up a basement wall and ceiling project.
The floor is of the open truss construction,and when ceiling is sheetrocked it will leave an approximately 2 foot open area above between the rock and the bottom of the first floor.
Perimeter cavities have been insulated with ROXUL.
My question is,do I need to put a vapor barrier up in the cavities?
spring3100 is offline   Reply With Quote
Old 05-26-2013, 07:23 PM   #2
Registered User
Rewards Points: 5,180
Where are you located?
Gary
Old 05-26-2013, 08:08 PM   #3
Rewards Points: 89
Zone 5 Gary,sorry about that
Old 05-27-2013, 01:16 AM   #4
Registered User
Thanks. Just seeing if my answer is pertinent or not. The rim board/OSB/plywood will be the temperature of the outside climate. On the inside it will be R-1.25 (per inch of solid wood) degrees less than exterior temp. Any vapor barrier used requires complete air-tightness or it will fail, which is why I always suggest foam/with canned foam or caulking; http://www.buildingscience.com/docum...ce-insulation/
How much, Zone 5? http://www.buildingscience.com/docum...r-requirements
It requires great attention to keeping the air barrier intact; http://www.carb-swa.com/articles/in%...Insulation.pdf
Be sure to air seal the framing/drywall ceiling and all plumbing/wiring/heating ducts/etc. holes that can admit air to the floor system cavities. http://www.buildingscience.com/docum...wall-approach/
I really don't see how a vapor barrier will work with an open truss floor as yours. IMHO, just add foamboard behind the Roxul (against rim). Pages 14-19 (even used Chicago- Zone 5); http://www.buildingscience.com/docum...ting-sheathing
Gary
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 08:52 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Basement Windows That Open In From Center ? FixingEverythin Building & Construction 2 04-11-2010 11:55 AM
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 10:37 AM
Open Truss ?s cloudkicker101 Carpentry 2 04-10-2006 09:40 AM
