Basement Insulation Without Sill Plate - Insulation - DIY Chatroom Home Improvement Forum
Old 01-10-2017, 12:57 AM   #1
Rewards Points: 6
I live in a single family house in Milwaukee, WI that was built in 1952. I'm looking in to insulating and finishing the basement over the next year. The basement does not have a sill plate unlike many of the guides I have found online. The floor joists simply sit on the foundation. The bricks are covered with concrete slabs on top of fabric that runs at a slight angle. Some of them have come lose or fallen off.
I haven't had any moisture issues and the floor joists are well above grade. You can see in the images below, the bottom of the window sits 4 inches above grade.
From reading around the internet and diychatroom.com, I found that I may want to leave or reapply the concrete to the top of the bricks. IF that were the case would I only add insulation above this concrete - between the floor joists?
What does this mean for a vapor barrier. Would I need to cover the concrete above the bricks as well?
Without completely finishing the basement and covering the entire wall with insulation, will I even see an improvement?
Thanks in advance.
hailmike is offline   Reply With Quote
Old 01-10-2017, 01:02 AM   #2
Rewards Points: 6
Re: Basement Insulation Without Sill Plate
It wouldn't let me post images since it was my first post.
Pics:
Thread I referenced: No sill plate
Should I insulate my sill plate? LVDIY Insulation 5 11-14-2015 06:44 PM
Waterproof Sill Plate, or Foundation, or French Drain? kgkg Concrete, Stone & Masonry 10 10-12-2013 01:32 AM
Exception? to using treated sill plate for basement walls BriBri Carpentry 3 12-13-2011 05:11 PM
Yes, Another Basement Insulation Question Beepster Insulation 7 11-30-2011 07:30 PM
Replace basement sill plate Bcoleman6 Building & Construction 7 01-15-2011 11:01 PM
