Basement Insulation Question ? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-23-2014, 11:00 PM   #1
Rewards Points: 203
I recently gutted my basement and want to start adding insulation. I'm unsure whether I should be using foam board insulation against the foundation walls, or whether I should be using the fiber glass insulation to the studs that are off the wall. I've read conflicting thoughts on this. Can someone provide some guidance. I'm in NY.
Jim Ignatowski is offline   Reply With Quote
Old 01-23-2014, 11:20 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,818
There are no conflicting thoughts on this matter.
Foam board is more expensive but the preferred way to properly insulated your basement walls in conjunction with interstitial wall insulation.
Old 01-23-2014, 11:31 PM   #3
Rewards Points: 203
I appreciate the response. I do have room for both. I'd prefer not to screw into my foundation walls, can you recommend an adhesive for mounting the foam board? Thx
Old 01-24-2014, 12:08 AM   #4
There are foam specific glues and they are widely available at your normal hardware outlets.
Start gluing and insulating.
Old 01-24-2014, 12:35 AM   #5
Dave Sal's Avatar
Rewards Points: 592
http://www.loctiteproducts.com/p/pl_...d-Adhesive.htm
Dave Sal is offline   Reply With Quote
Old 01-24-2014, 12:36 AM   #6
Rewards Points: 203
Thanks Everyone! Appreciate it
Old 01-24-2014, 07:52 AM   #7
Rewards Points: 125
Thumbs up
You're right, there may not be conflicting thoughts on it but it can be difficult for us noobs to sort through all the science involved and make sense of it. People want to just throw FG in and call it good when the reality is that differing types of insulation function differently, and when you factor in the various aspects of conduction/convection/radiation spiced with a dash of thermal bridging it can be a tad daunting.
The input from all the mavens here is greatly appreciated
ThatDaveGuy is offline   Reply With Quote
Old 01-26-2014, 05:14 PM   #8
Rewards Points: 203
I have a follow-up question on this if someone has the time. If the foam board is not continuous because of obstructions, will that nullify the effect? Meaning if I can only cover 3/4 of the foundation wall with foam board, will that still help or make things worse?
This is an old house where everything was originally mounted on the concrete walls, electrical receptacles were embedded, etc... Thanks
Old 01-28-2014, 02:46 PM   #9
Registered User
Rewards Points: 5,216
The amount of wall you cover is saving the most on your heating bill; http://www.quadlock.com/technical_li...Insulation.pdf
Which Zone are you located in?; http://energycode.pnl.gov/EnergyCode...ate=New%20York
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
rrudd2 (01-29-2014)
Old 01-28-2014, 07:57 PM   #10
Rewards Points: 203
Great info ... Thanks Gary! I'm located in Zone 4
Old 01-28-2014, 09:07 PM   #11
Dave,
I do not doubt that the information is tough to sort through and I assure that it is difficult for the pros to keep up the science and ever evolving technology.
I promise you that if you asked 10 contractors the same question on insulation, you would get 10 different answers and probably 8 or better would be wrong by current building science standards.
Keep on researching and you will find out what is right for your application, home, and climate.
Guys like Gary, jklingel, Tom Struble, Joecaption, etc., provide a wealth of both technical and application information. Pick through their posts and you are getting the benefit of over a hundred years of experience.
Old 01-28-2014, 09:23 PM   #12
Registered User
For your location, R-10 foam board or R-13 cavity fill is required. If you check locally you should be able to mix-n-match to get total R-value. If not, show the inspector this, pp. 11 or 12, footnote "c" for "basement insulation"; http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Keep in mind the more cavity fill fibrous you add; the weaker it makes the foam board against condensation; the colder the inside face of FB. R-10 FB and no cavity fill is fine and optimum, the cavity moisture will be controlled by the HVAC as the studs/insulation is in the conditioned space; http://www2.dupont.com/Tyvek_Weather...20Bulletin.pdf
Option 2; less amount of FB, with some cavity insulation; need closest large city to figure local dew-points based on foam thickness....
Option 3; wood frame wall with cavity insulation only. If choosing this, I can explain it better.
Gary
PS. Dave, add WoW to that list! Thanks!
Old 01-28-2014, 10:22 PM   #13
Rewards Points: 125
I have nothing but praise for this site, the people here sharing their expertise so willingly have taught me a great deal and saved me a lot of time and effort. Just reading through threads that have no bearing whatsoever on my projects has taught me a lot in details or materials or sometimes just looking at a problem differently.
Maybe the single most important thing I have gotten from reading here is the realization that there is no ONE answer to any of it, assessing and diagnosing my particular situation is the hardest part but the one that determines the outcome. Having this kind of access to pros that know is one of my most valuable tools.
The Following User Says Thank You to ThatDaveGuy For This Useful Post:
Dave Sal (01-29-2014)
Old 01-28-2014, 11:21 PM   #14
Roger that.
That is why we ask folks so many time to post up where the home is, what their home construction is, picture, etc.
Keep researching and know that you are miles ahead of 99% of your other homeowners in your knowledge base and thoughtful approach.
Old 01-29-2014, 08:53 PM   #15
Registered User
Any other questions, Jim?
Gary
Tags
basement , foam , foundation , insulation
Another Basement Insulation question.... Sunnybono Insulation 4 04-20-2013 06:42 AM
Basement finishing Insulation question. mopar44o Building & Construction 12 01-04-2013 04:30 PM
Basement Wall Insulation Question doublejz Insulation 2 12-17-2012 01:38 AM
another basement insulation question, with a twist? Amateuralex Insulation 1 04-17-2012 04:11 PM
basement with garage insulation question WS6transAm General DIY Discussions 7 01-21-2011 07:15 PM
