Basement Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 10:12 AM   #1
basement insulation question
I have a basement that was put up by the builder with studs and fiberglass insulation .. I was planning to drywall the basement to make one big open room. What i was wondering is if i should take down the fiberglass and poly. Then install foam board by cutting a section out so i can slide it down the wall into place against the concrete.
I have about 1 inch and 3/4 gap between the studs and basement concrete wall.
I am not sure how this would work for glue application with such a tight fit. Maybe use spray foam on top and joints? Then tape them?
Sorry for all the questions.
pete126 is offline   Reply With Quote
Old 09-09-2012, 12:12 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
Where is the home located?
No need for poly and foam board. Foam board will serve as an effect vapor retarder if properly applied.
Old 09-09-2012, 12:26 PM   #3
The home is located in Alberta Canada.
Old 09-10-2012, 06:39 AM   #4
I would definitely take down the FG and poly combo. Not a great option for up there.
Rigid foam and air tight drywall is the way to go in your application.
Check out Building Science.com as they have a bunch of wall designs that are perfect for your climate.
another basement insulation question, with a twist? Amateuralex Insulation 1 04-17-2012 03:11 PM
basement with garage insulation question WS6transAm General DIY Discussions 7 01-21-2011 06:15 PM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 12:01 PM
