-   Insulation (http://www.diychatroom.com/f103/)
-   -   basement insulation question (http://www.diychatroom.com/f103/basement-insulation-question-156284/)
pete126 09-09-2012 10:12 AM
I have a basement that was put up by the builder with studs and fiberglass insulation .. I was planning to drywall the basement to make one big open room. What i was wondering is if i should take down the fiberglass and poly. Then install foam board by cutting a section out so i can slide it down the wall into place against the concrete.
I have about 1 inch and 3/4 gap between the studs and basement concrete wall.
I am not sure how this would work for glue application with such a tight fit. Maybe use spray foam on top and joints? Then tape them?
Sorry for all the questions.
Windows on Wash 09-09-2012 12:12 PM
Where is the home located?
No need for poly and foam board. Foam board will serve as an effect vapor retarder if properly applied.
pete126 09-09-2012 12:26 PM
The home is located in Alberta Canada.
Windows on Wash 09-10-2012 06:39 AM
I would definitely take down the FG and poly combo. Not a great option for up there.
Rigid foam and air tight drywall is the way to go in your application.
Check out Building Science.com as they have a bunch of wall designs that are perfect for your climate.
