Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 07-07-2011, 12:36 PM   #1
Basement Insulation Question
Is FORMULAR 150, 1" thick with a rating of R-5 enough for a standard walk-out basement? Will be gluing directly to the block. Should I go with 2"?
ctote is offline   Reply With Quote
Old 07-08-2011, 08:30 AM   #2
ccarlisle's Avatar
Depends on where you are. Not enough for Fairbanks, too much for Atlanta...
ccarlisle is offline   Reply With Quote
Old 07-08-2011, 09:12 AM   #3
Southwest Virginia
Old 07-09-2011, 07:32 PM   #4
Moderator
You are in Zone 4A: http://publicecodes.citation.com/ico...001_par001.htm
You need 2" for minimum Code of R-10 (continuous) -footnote "c": http://publicecodes.citation.com/ico..._11_sec002.htm
Gary
Clothes taking longer to dry?
Old 07-15-2011, 02:26 AM   #5
2 inch would be preferable in most northern states or Canada. So long as it doesn't present a problem for your design plan, then go for it! Worth the expense.
design_lover13 is offline   Reply With Quote
Old 07-20-2011, 08:55 AM   #6
So if I go with 2" from Home Depot (about $30 for 4x8 board) I'm looking at around $795 ... for the 3/4" tongue-and-groove (about $14.20 for 4x8 board) I'm looking at around $375. Any estimates on how long it will take to make that additional $400+ back in energy savings?
Old 07-20-2011, 11:15 AM   #7
Architectural Designer
AGWhitehouse's Avatar
No way of telling for sure without running an energy model, but my guess is that over the life of the product you will at least double, if not triple, your investment with whichever one you choose to do.
AGWhitehouse is offline   Reply With Quote
Old 07-21-2011, 12:19 PM   #8
Moderator
I agree with AGWhitehouse, above. Here are some figures on foam board and heating in a basement for a little comparison of savings generated; http://www.quadlock.com/technical_li...Insulation.pdf
And the basics on thickness of board;http://www.buildingscience.com/docum...lation-systems
http://www.eere.energy.gov/buildings...s/db/35017.pdf
Explore this one, using "back" key; http://www.buildingfoundation.umn.ed...timum-main.htm
Gary
basement with garage insulation question WS6transAm General Discussion 7 01-21-2011 07:15 PM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 01:01 PM
