-   Insulation (http://www.diychatroom.com/f103/)
-   -   Basement Insulation Question (http://www.diychatroom.com/f103/basement-insulation-question-109947/)
ctote 07-07-2011 11:36 AM
Is FORMULAR 150, 1" thick with a rating of R-5 enough for a standard walk-out basement? Will be gluing directly to the block. Should I go with 2"?
ccarlisle 07-08-2011 07:30 AM
Depends on where you are. Not enough for Fairbanks, too much for Atlanta...
ctote 07-08-2011 08:12 AM
Southwest Virginia
Gary in WA 07-09-2011 06:32 PM
You are in Zone 4A: http://publicecodes.citation.com/ico...001_par001.htm
You need 2" for minimum Code of R-10 (continuous) -footnote "c": http://publicecodes.citation.com/ico..._11_sec002.htm
Gary
design_lover13 07-15-2011 01:26 AM
2 inch would be preferable in most northern states or Canada. So long as it doesn't present a problem for your design plan, then go for it! Worth the expense.
ctote 07-20-2011 07:55 AM
So if I go with 2" from Home Depot (about $30 for 4x8 board) I'm looking at around $795 ... for the 3/4" tongue-and-groove (about $14.20 for 4x8 board) I'm looking at around $375. Any estimates on how long it will take to make that additional $400+ back in energy savings?
AGWhitehouse 07-20-2011 10:15 AM
No way of telling for sure without running an energy model, but my guess is that over the life of the product you will at least double, if not triple, your investment with whichever one you choose to do.
Gary in WA 07-21-2011 11:19 AM
I agree with AGWhitehouse, above. Here are some figures on foam board and heating in a basement for a little comparison of savings generated; http://www.quadlock.com/technical_li...Insulation.pdf
And the basics on thickness of board;http://www.buildingscience.com/docum...lation-systems
http://www.eere.energy.gov/buildings...s/db/35017.pdf
Explore this one, using "back" key; http://www.buildingfoundation.umn.ed...timum-main.htm
Gary
