Basement Insulation Calculations - Insulation - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 10:09 PM   #1
bryanp22's Avatar
Rewards Points: 290
Basement Insulation calculations
Can someone explain the calculations I have seen in threads for basement insulation? I am in zone 6. I was planning on using roxul in the cavities but I am having trouble figuring out what thickness XPS. I was really hoping to use none or 1" at the most, but I am not sure if that is recommended.
bryanp22 is offline   Reply With Quote
Old 06-16-2013, 09:22 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
1" should be fine.
Paging Gary for the tables and clarifications.
He is a code wiz!!!
Old 06-17-2013, 12:10 PM   #3
Rewards Points: 660
After plenty of research, I did 1" on my basement walls in Minneapolis. 2" may be "best", but if your humidity levels in your basement are not too high, you should be fine.
B
Beepster is offline   Reply With Quote
Old 06-17-2013, 12:21 PM   #4
concretemasonry's Avatar
Rewards Points: 2,594
Just keep in mind that the earth is a great moderator of temperatures and it does not vary too much when you get below 3' to 4' or so, even though there may be a few consecutive days of -20F nights. Because of this, less insulation is needed for basements this, than for above grade portions of homes. I have seen frost penetration of only a few inches under a good snow cover even after a month or more of -10 to -30F.
If you condition the space (heat and AC) too much insulation prevents some of the benefits of being below grade if you have proper low returns on at the lowest level.
concretemasonry is online now   Reply With Quote
Old 06-17-2013, 01:05 PM   #5
bryanp22's Avatar
Rewards Points: 290
Okay good info. Only about two feet is above grade. What would be a better approach? Do I even need insulation? Or just the two feed above grade?
Old 06-19-2013, 12:44 PM   #6
bryanp22's Avatar
Rewards Points: 290
So if I do 1" xps is R15 roxul overkill between the studs?
Old 06-19-2013, 06:52 PM   #7
No.
Insulation, even when below grade, is recommended.
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
